So years ago I decided to rip out all of the wires and rewire the car (because there was a small on ocassion from behind the instrument panel, likely just a small break in a wire that I could've just found & taped. Wasn't the best idea 'cause the car ran fine b4 that & the fact I've never rewired a car. Soon found although I'm able to read a wiring diagram, the project wasn't as simple as I thought & the Haynes manual diag. wasn't ideal as it was on several pgs & required a lot of flipping pgs while following wires. I got a diag on cd that was much easier 2 follow & got started. In hindsight it'd have been simpler 2 have laid all new wire 'cause whoever wired the car b4 I got it did a sloppy job & none of the wires wanted to line up quite right again. Finally got mostly done but some wires still need 2 b moved down & attached. Can't work on it where it's now & decided 2 just buy a wiring harness to replace them & make things simpler. Anyone suggestions where 2 find one? (Pref. cheaper than ezwire/used?/salv?)
