Here’s the quick run down on what I’ve got so far
Started with an 81 Datsun 720 diesel,
couldn’t get it running and after doing tons of research (not actually very much) found that there’s virtually no parts available for that truck
I had fallen in love with the truck and wanted to use it as a daily driver, snowboarding and getting around
Figured the best thing to do would be a body swap onto a modern drivetrain
in comes the 2004 Subaru WRX
Stripped the car down to this point
Within a few days had the truck cab fitting where I wanted it. It looked great but was only sitting on wood blocks and straps holding it together. Now started the long journey of mounting it to this chassis.
Now I had completely removed the structure of the WRX chassis and needed to strengthen it up, so I built an 8 point roll cage out of 1-3/4” DOM tubing
Once the cage was fully welded I got the cowl all sorted out
I learnt that there’s is a tremendous amount of work in tying both the inner and outer cowls in
The hood is much longer on the Subaru than the truck so I was going to have to stretch it. As soon as I knew that I would be stretching it for sure I was going to try to emulate the Hakotoro Sunny truck and get the grill shape to look like the Hakosuka GTR
I really like the shape of the grill so far, and as far as the rust on the rest of the truck I thought that if I was to cut it all off and do a wide body like the Group B rally cars of the 80’s that’s be the simplest
I built a side skirt out that that same DOM tubing and the rear bumper
Shortened the box by about 7”. It’s now wider than it is long, hahahaha
that’s where I am up to date, please let me know what you think so far
