Hmm, ok, so maybe I should look at the base timing. I know vacuum is good and based off your description of the timing adjust system; it shouldn't be activated under full throttle load. This issue is persistent across even low rpm so that would negate the mechanical advance as the issue aswell. Since my ignition system is all fresh (plugs, rotor, cap,and wire), it should rule out faulty ignition, guess I just gotta bite the bullet and pick up a timing light instead of just tuning by ear. In my conceptual understanding of the system if I want to effectively set the base timing, I should disconnect the vac advance, and the secondary ignition coil, and then add those systems back in after the 5d BTDC has been calibrated.
Sound good?
