So I bought a 2006 STI r-180 limited slip rear differential for my Datsun, and have prematurely installed the axle stubs from Futofab.com, before putting the cv axle bolts on them... stupid me.. the differential has internal c-clips holding the axle stubs in.. does anyone know the correct way to remove the c-clips holding the axles in??
Hi,
looking to find some direct bolt on rear shocks for my 71 510 sedan. Something that is quality but doesn’t break the bank. Also is there a donor car that would supply bolt on front suspension for my car as well??? Maybe a 240z or a BMW??? I believe the front suspension are coil overs...
thank you!
I have 2 piston Wilwood disc brakes for the rear of my Datsun, and am looking to get some 2 piston disk brakes for the front as well (preferably Wilwood brand). The brakes I have work with my 14” wheels. Does anybody have any suggestions as to where I might be able to find some front brakes that meet the criteria listed above?? Thank you for your help!
I’ve been looking for a while now, and cannot seem to locate a chassis harness for a 1971 Datsun 510 sedan with an s13 SR20DET motor... Any ideas as where to find an affordable and easy to install wiring harness is?? Any help would be great!! Thanks!
