54 -
Not Telling
Cambridge ON
2006 Subaru Outback XT and 1972 510
JPE16's Achievements
32
A quick video about the car (yay more moving pictures)
Just a quick 8 min vid a friend of mine put together about my car and it's journey to completion:
hahaha, no problem! Sorry to have let this die sort of! The car is in storage now for a few months while I get sort of stupid. I'm currently building a tow rig. It's a 1995 regular cab Silverado dually. The plan is a stock floor body drop, bagged on 22" transport truck wheels, and painted black by spring. We'll see how that pans out, as I'm also getting my feet wet in rallycross with a few friends and will be doing the build and maintenance on the car we've bought. The most exciting news is that the car got a write up on motoiq!!!!!!!!! I'm so pumped and humbled by that. http://www.motoiq.com/MagazineArticles/ID/3654/Datsun-510-Are-You-Sure.aspx Here's some pictures from my last big track event of the year, please enjoy. I will be getting back to the car early spring, so expect some updates around that time, as I do have a to-do list before next summer!
Some moving pictures for the complainers, lol
Mooner took some pics of the car before we loaded it up on Friday....right before the diff exploded.
Indeed I do SO, we took the car out to to TMP for a shakedown run on sunday, and I couldn't be happier. The car did nine sessions, and only encountered a couple small issues, with no mechanical failures. IT just wanted more. It definitely requires ALOT of work still to make it work well. Because of how poorly it was handling under braking, cornering, and accel we only times one session, and the fastest lap from that session was a 1:26.3 At any rate, my parents surprised me at the track, and I took both my mom and dad out for a few laps. It was pretty surreal to be bombing around tmp in the car with them on board. It was a great day, I'm still on a high, and can't wait to go back on Friday and start to get the car dialled in. Anyway, Papa Ellis snapped a few photos: I will get some video friday if i remember.
So, some things have happened since I last updated this. I drove the car the other night, and to my delight, found very few issues that need addressing (besides working on my driving...). I'll just go through and let the pictures and captions do the talking. Oscar primed the car: I then finished up the underside, including the exhaust: Next, I finished up the heat shield, made a coil pack cover, and finished up some odds and ends in the engine bay: H at Spec-Auto sourced a second set of wheels for me on short notice: Finished up the trunk: The gauges went in their home and got wired up The front of the car got assembled: Brake and clutch set up: And finally, off to paint: That's all for now!
This car hasn't been forgotten about! It went away for some things and came back a running, turning, stopping, moving car...on the back of our resident bad-ass car-hauler of course: It's also no longer yellow: And way more complete: I will update accordingly with the full story and way more pics when I have time
Small update: So We had the engine in and out, and in and out, and it's looking like the tranny tunnel needs to be remade to accommodate the S2000 six speed. So I did a little cutting, and bam, it fits. I'm hoping to build the new tunnel tonight. Some other less significant things happened: The walbro found its way into the tank: I made my lexan rear quarter windows: and my dash face finally showed up from laser cutting: The body work is coming along as well, but who wants to look at pictures of sanding.
Hahaha, If that's the only thing wrong with the build, then I accept that! I'll try to be more careful in the future though. The isolator is a piece of a roller from a boat trailer. I finally got around to replacing the sheet metal screws that were holding the brake lines on with nut-serts Next up, was something else rather exciting. I buttoned up the engine mounts, put the cross member in, and then stuck the motor in. Turns out I can measure, and stick metal together. Crank was dead nuts centered, and the motor was straight and exactly where I wanted it. I was pretty happy after it was all tightened down. Next up, Ryan from Ryan Maxwell Racing came by and finished up the wiring on the trunk And he also finished the center console: And then he stuck it all together, and turned the key, annnnnnndddd.... We have electricity! From the light on the ecu and fuse box to the tail lights, everything fired right up and worked. I tell you it was a majorly uplifting feeling to see that car sitting there with the motor in and the hazards flashing away. And this is all after we had a major party to celebrate my cousin heading to Sochi to represent Canada on the women's Snowboard team, competing in slope style! Everyone send good vibes Jenna Blasman's way!
Lets see if I can make sense of what I have done over the past few weeks. Unfortunately life happened over the break and I didn't get to spend nearly as much time on the car, however I now have more room to sleep, and less time I'm required to be at home. I had the engine in and out a few times. I have been looking at other swaps, and I don't really see any I'm in love with. i don't really like how alot of them solved some of the problems. So, I took some time to think and come up with some solutions. On the top of my list was not hacking up the firewall and transmission tunnel. Secondly was to leave room to add a rack down the road. So after much consideration, I decided the best way to keep the engine forward (to allow me to access things on the firewall, and leave room for the largest part of the bell housing, making it easier to work on) and as low as possible. To do this I would need to either a) make a new drag link (or bend the existing one, although adding that much heat to a 40 y/o cast part doesn't strike me as smart) b) switch rack and pinion immediately or c) make a new oil pan. After some investigation, it turns out the rear portion of the pan that's in the way doesn't hold any oil. So, that made my decision rather easy. Next job was to make up a new crossmember. I had started on this before the last step, and it looks ugly now, but the ultimate goal is to make it look like one piece. It also allows me to mount a rack on it down the road. So, I sent the pan out to have the offending casting machined off, got it back, and welded some plates on to give it back SOME structural rigidity. I test fit it, and it worked a treat. i could now position the engine exactly where I wanted it, retain the factory drag link, keep the tranny tunnel massaging to a minimum, and have room to work on the back of the motor. Unfortunately I dont have any pictures, but my dialing in of the tig welder on aluminum hardly went smoothly, so perhaps it for the best no one see those. However I did get it close enough to stick two pop cans together. A few tacks was the best I could manage after a few minutes practice Having the pan off, i also had a look at the bottom end. I think I believe this guy now about the whole 8000km thing Jumping ahead slightly, after a ton of measuring, and positioning, and measuring, I popped the motor back out and began fabbing mounts. 200 points to whoever guesses with the rubber isolators are made of. Bolts welded to the back of the plates Bolt, plate, and isolator in their home Side plates added, and buzzed onto the crossmember Tomorrow I will likely put the inside plates on, tig it all up, and get it ready for final instal. So, over the break I got a bunch of other things done, not all of them productive. I spent some time practicing my tig welds (naturally on someone else's car) and welded some struts up for my friend James who's building a heck of a 280z! Tig welding is all practice, so I stuck together a new holder for cellphones at the door (the only place we get reception) Got my seats all mounted and ready to go in and popped by my parents place to use their, rem, parts washer Also got a pretty sweet christmas present from my dad And lastly, I hit up the motorcycle show with some friends and picked up all the gear I need to ride my other new toy Anyway, I'm sure there's things I'm forgetting. At any rate, for those who've been following the build, I should have more updates to come, and look forward to any input. Thanks for reading guys!
So, as a result of the engine change, I'm going to have to build a custom cross member, and the first step of that is to cut apart the old one. So within hours of my last exam, I had the cross member cut apart and ready to have the ends plated, go back in the car, and get squared up to start building the new member. I didn't snap any pictures, but I did get the plates on the ends of the cross member ends. I also removed the engine mounts. The motor will be sitting further back, and at a different angle, so my plan is to use the stock s2000 mounts and build a lower part onto the cross member to accommodate a bushing/isolator of some sort. I also Tig'd together the plates, and noticed I'm getting quite a bit of porosity. I'm going to take them into work tomorrow and blast them and hot it's just dirty metal, as it's fine in some spots, and terrible in others; but any input is welcome. I also realized I hadn't posted any pictures of the new shop. I love this place! We have a great group of guys, six amazing projects, lots of skill, and a great selection of tools. plus puppies. Sorry to gush, but I'm so pumped to build so many things. Having a hoist, tube bender, chassis table, and the people, skills, and other tools to build pretty well anything has me quite excited! At any rate, here's a couple pictures of why I love this place. I also got the aluminum bosses in from the machine shop to weld onto my core so I can put my aluminum top mount on the legacy.
I was honestly in the same boat. I couldn't get over the fact the motor wasn't Nissan built. But after a lot of research, it was hard not to go with it. I got the steel bent for the cross member, so ideally that will start to take shape this weekend. It's going to be very tight with the bell housing clearance. I know I'll have cut the tranny tunnel to accommodate the shift rod, but I'm hoping to avoid making any major cuts in the engine bay. At any rate, I was thinking of making a jig for the cross members if anyone needs one in the future, and my wiring guy has everything laid out for future use, so if anyone has any questions, I would be happy to answer them about the swap. I stopped by his place to look at my oh, so pretty Deatsch Works connectors: My ecu board is done enough for me to find it a reasonable home in the car: We're just waiting on the raychem for the engine harness, and it will be all done.
Haha, thanks man. the car WILL NOT be staying yellow. I'm pretty set on gloss black.
240BHP stock actually. Reasonably easy to get near that in torque with carefully chosen parts and a good tune too.
