beat-up-bluebird71 Posted February 25, 2009 Report Share Posted February 25, 2009 hello. new to the forum noticed all the great advice everyone gives and recieves i recently bought a 1971 four door 510, stock l16 motor, and found a 69 2000 roadster rotting away in a junk yard, good amount of parts if anyones looking... anyways i was curious if the dual su carbs on those roadsters will fit on my 510 after a rebuild or what would be needed to make it work it also has a sunline racing header if that would fit or anyone is looking, mainly i just want a dual carb setup for mine and was curious as to if they would fit right on or even work before i make the purchase..... thanks for the help tyler Quote Link to comment
datzenmike Posted February 25, 2009 Report Share Posted February 25, 2009 The Roadster can be made to fit but you will need a manifold for it. Possibly an L16 SSS manifold. Quote Link to comment
MikeRL411 Posted February 26, 2009 Report Share Posted February 26, 2009 You will need a single container brake master cylinder if you want to put any kind of air cleaner on the rear SU. NISMO catalogues listed this and parts needed to add SUs to the 510. Quote Link to comment
mklotz70 Posted February 26, 2009 Report Share Posted February 26, 2009 Any chance you can get a pic of the header? Quote Link to comment
Duke Posted February 26, 2009 Report Share Posted February 26, 2009 You will need a single container brake master cylinder if you want to put any kind of air cleaner on the rear SU. If the roadster SU's are similar size (dimension wise, not throttle bore) to standard 510 SU's, then they will fit fine with the standard brake master cylinder. No need to switch to the single reservoir one. The thing that you would need to find is a manifold for the l-series that accepts the 4 bolt roadster SU's. They are out there but a little hard to find. Quote Link to comment
mklotz70 Posted February 26, 2009 Report Share Posted February 26, 2009 sorry it's so blurry, but you can get an idea of positioning :) Quote Link to comment
datsunrides Posted February 26, 2009 Report Share Posted February 26, 2009 R16 carbs are 2 bolt. Kinda hard to see in the pic. The U20 carbs are 4 bolt. Mark Quote Link to comment
pl521sss Posted February 26, 2009 Report Share Posted February 26, 2009 You will need a single container brake master cylinder if you want to put any kind of air cleaner on the rear SU. NISMO catalogues listed this and parts needed to add SUs to the 510. It will clear without using single MC and just 1 or 2 inch tall K&N Filter. Different story if you use the OE SU filter housing, that will hit the dual MC. Quote Link to comment
beat-up-bluebird71 Posted February 26, 2009 Author Report Share Posted February 26, 2009 thanks for all the advice. i have heard lots of different things haha anyone for sure if the sss manifold will work:confused: if not i guess i will find out the bores didnt know if anyone could save me some searchin :D and also i messed up the name of that header, it is a rising sun racing header i guess they specialize in datsun roadster stuff i will try and get some pics up this week... thanks again for the help Quote Link to comment
mklotz70 Posted February 26, 2009 Report Share Posted February 26, 2009 I just realized it was a 2000 roadster.....I just picked up a G15...which is different....so I doubt it will fit. So...don't go out of your way for the pic...but if you're there already :) Quote Link to comment
67411sss Posted February 27, 2009 Report Share Posted February 27, 2009 I have a nice G15 head taking up space Mike;) Quote Link to comment
ppeters914 Posted February 28, 2009 Report Share Posted February 28, 2009 The 2000 roadster used 46mm SU's, which, according to the Ztherapy folks, will be serious overkill on a stock L16/L18 motor without headwork/porting/etc. Yeah, they'll work, but you'll experience a boggy low-end. Unless you really want/need that top-end, the 38mm SU's (from 1600 roadster or SSS L's) are a better choice. Quote Link to comment
anotherjoe2000 Posted February 28, 2009 Report Share Posted February 28, 2009 The L-series SSS manifold uses the 2 bolt carb (like on a 1600 roadster - 38mm) Here is one for sale - http://www.datsunlandsocal.com/index.php?main_page=product_info&cPath=17_37_40&products_id=343 Quote Link to comment
beat-up-bluebird71 Posted March 1, 2009 Author Report Share Posted March 1, 2009 (edited) ppeters: yea i just was wonderin how hard it would be i dont really need a head. the roadster seems to be the only other datsun in iowa driving or in a junkyard haha so i was seeing what it would take. so the 2000 su's are four bolt right? and in my case a 1600 would have been the ideal find then.... so what would the advantages be from using that head? anotherjoe:too bad i didnt find a 1600, but thanks for the manifold hookup! 67411sss:haha thanks but i dont need a head, just wantin some carbs :) Edited March 1, 2009 by beat-up-bluebird71 Quote Link to comment
damon Posted March 3, 2009 Report Share Posted March 3, 2009 I thought that the 1600 roadster and the 510 SSS carbs are different? the SSS are mirror of each other front to back and the 1600 roadster are the same front to back. and isn't the butterfly reverse on the roadster compared to the 510 SSS? I know that visually they are different. I think it is explained on the ZTherapy video they give you when you buy parts or casrbs from them. It's a VHS tape. Quote Link to comment
mklotz70 Posted March 4, 2009 Report Share Posted March 4, 2009 seems there's a couple of SU threads going right now....I think it was one of the others I said I'd post pics in.......but I'm here.... You can see the angle of the fuel bowl in the first pic. these are L series...big SU's. You can see what Damon is talking about with the mirror image stuff. The last pic is of the small carbs on a roadster eng.....they are the same...not mirrored...the linkage is the indication. Quote Link to comment
MikeRL411 Posted March 4, 2009 Report Share Posted March 4, 2009 Definitely early roadster engine. Square rear corner to the valve cover and no "PCV" oil vapor recycling gooseneck on the rear of the valve cover. Quote Link to comment
mklotz70 Posted March 4, 2009 Report Share Posted March 4, 2009 it's a '64 G15. You can check out my NL320 thread if you want to see why I have it :) Quote Link to comment
79datsun620 Posted March 27, 2009 Report Share Posted March 27, 2009 mklotz70, these pics are helpin me with my project,thanks:D Quote Link to comment
ggzilla Posted March 28, 2009 Report Share Posted March 28, 2009 I think most of those pictures are Datsun Hitachi carbs rather than SUs. Yes, there are two Hitachi sidedraft sizes: 46mm: fitted to Z-cars (L-series sixes) and the 2000 Roadster 38mm (1.5 inch): fitted to the L16 engines, and almost all other Twin-carb Datsuns except above Yes, you want the 38 mm for four cylinder L-series engines Yes, among 38s there are differences in right/left pairs and right/right pairs, mainly the linkage varies between these setups. Also the L-series and A-series carb looks the same but the linkage again is different. And geninue SUs carbs (from european cars) use different linkages. But they will fit the same manifold if you can figure out the linkage opportunity. The newer manifolds (1976-up?) are 38mm four-bolts, and will take a 2-bolt or 4-bolt carb. There is some encyclopedia information here: Hitachi Twin Carb. See section 'Variations' Quote Link to comment
Wharf Rat Posted March 29, 2009 Report Share Posted March 29, 2009 Thought I would add these carbs love Marvel Mystery Oil in there damper pods. And it smells nice, any extra giving to them when filling the older engines love so don't worry about over doing it, they seek there own level:) Keep a old pump type oil can on your bench just for your MM:D Peace WRAT (If you like you can call me that ol' bastard on the eastcoast) OLD SCHOOL TIL I DROP Quote Link to comment
dbrick Posted March 30, 2009 Report Share Posted March 30, 2009 Good news is the 2000 carbs are in demand, so you should be able to swap them for the 1600. Put a post on 311's.org, and you'll probably get a taker. Quote Link to comment
