  • Replies 57
how do you reindex the tosion on these?
spotted your thread on there also porkchop: http://www.volksrods.com/forum/showthread.php?t=15725&highlight=torsion
ive been reading for awhile now and can't seem to find a simple process. its not like a Datsun that's for sure. :blink: ill keep reading and hopefully find something.
Edited by ariascarlos1990
yeah watched all 4 and the 2 for the front.
Thanks
No problem. The video for the front (if on the same car) will do you no good. That Type 3 has a completely different suspension from regular bugs, and especially your Super. the Super Beetle actually has a strut front suspension.
Do something like this IMO. Maybe not to one in as good of condition yours is, but I would kill to have a racing beetle. midship turbo flat 4 would be epic.
If you were gonna do something like this, a Super would be the one to do it to. You might also look into the German Look scene which involves more of a road racer setup, disc brakes, big wheels (usually Porsche), large displacement engine with Porsche style cooling, etc.
Yes, that will work, but I use a different style of adjuster. The style of adjuster in that thread works just as well if you do a little research and make sure you don't buy a brand that has issues with the teeth or set screw stripping. I have built quite a few beams and have had really good luck with these adjusters: http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4032
If you wanna go really low, you will also need these :http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4193
and these: http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4192
I would suggest a set of dropped spindles and narrowing your beam if you really wanna go low with it.
