erichwaslike Posted January 14, 2011 Report Share Posted January 14, 2011 if u are doing 2 tubes and sandwiching the bag mounts between em ur gonna want to use something like 1.25od x .095 wall thickness. anything from there up shood be ok. id also put in some triangulation to keep the bars from wanting to flex where they are welded to the frame, and plate the frame with 3/16 or 1/4 plate like 4 inches in both directions from the tubes to help spread the load out on the rails so it doesnt tear off them. welding tubes to unibody rails without plating never turns out well after time, i will almost guarantee if u dont it will crack the rails around the welds Quote Link to comment
freaky510 Posted January 14, 2011 Report Share Posted January 14, 2011 if u are doing 2 tubes and sandwiching the bag mounts between em ur gonna want to use something like 1.25od x .095 wall thickness. anything from there up shood be ok. id also put in some triangulation to keep the bars from wanting to flex where they are welded to the frame, and plate the frame with 3/16 or 1/4 plate like 4 inches in both directions from the tubes to help spread the load out on the rails so it doesnt tear off them. welding tubes to unibody rails without plating never turns out well after time, i will almost guarantee if u dont it will crack the rails around the welds Cool thanks for the input!! i was planning on plateing/boxing the inner wheel as well. Looks like I am off to cut some more cardboard and finish mocking it up I only have a welder for the weekend. again thank you for all your input it has been alot of help Quote Link to comment
erichwaslike Posted January 14, 2011 Report Share Posted January 14, 2011 just wondering wat kind of welder are u using, flux core, mig, tig, 110v, 220v? Quote Link to comment
freaky510 Posted January 14, 2011 Report Share Posted January 14, 2011 just wondering wat kind of welder are u using, flux core, mig, tig, 110v, 220v? I am going to tack evetything with a 110 fulx. then take it over to a buddies and he will weld it up.He has done most my welding. As for his wleder it has gas and no one but him can use it :lol: is all i know about it Quote Link to comment
erichwaslike Posted January 15, 2011 Report Share Posted January 15, 2011 hmmm is it wire feed or does he hold the torch in one hand and filler rod in another? Quote Link to comment
freaky510 Posted January 15, 2011 Report Share Posted January 15, 2011 hmmm is it wire feed or does he hold the torch in one hand and filler rod in another? LOLZ It's all wire feed the loaner and the buddies. Got your message thats some nice work you have done there! :thumbup: ! :w00t: ! So the damn steel yard wouldn't sale me just 6' feet of tubing had to buy 20' and i don't want 20'.!.!. So good Ole Ricky saves the day again hooked me up with some 1X1 not what i was looking for but it will work and it was FFRRREEEEeeee I got a couple of cuts made last night then realized i was to BUZZED to be working :unsure: :rolleyes: :lol: So the coffee is almost done and I am off to play!!!!!!!!!!!!!!!!! Quote Link to comment
erichwaslike Posted January 15, 2011 Report Share Posted January 15, 2011 the 1x1 how thick is it? Quote Link to comment
freaky510 Posted January 16, 2011 Report Share Posted January 16, 2011 the 1x1 how thick is it? kinda thick I was hopimg to find thicker stuff,but my buddy swears it will work. So spent most the day working on the 411 got almost all the pieces made. As for pics uummm shitty cell phone is all i got and well i havent figured out how to share them yet. my pc wont upload the and my photobucket is being well photobucket lolz Quote Link to comment
freaky510 Posted January 16, 2011 Report Share Posted January 16, 2011 these are all just cut to try it out all will be cleaned and painted and look what i ordered LOLz It came in last week to our local library Quote Link to comment
freaky510 Posted January 16, 2011 Report Share Posted January 16, 2011 these are all just cut to try it out all will be cleaned and painted yes i know the bag is upside down and look what i ordered LOLz It came in last week to our local library Quote Link to comment
erichwaslike Posted January 17, 2011 Report Share Posted January 17, 2011 these are all just cut to try it out all will be cleaned and painted and look what i ordered LOLz It came in last week to our local library make sure u get the bag mounts set so the bag top and bottom plate are flat with each other and the bags not twisted or the centerlines off. when completly empty and flat u want it in a static state as far as twist and all that, ur bag will last longer that way casue it wont be rubbing itself in an unnatural way and causing premature wear. just a heads up. a good way to set it up is to put the car on jackstands and the axle too at the hright u want it when the bag is empty. use a few peices of all thread and some nuts and bolt the mounts together at the collapsed height of the bag ur using based on the specs of the bag. set ur bump stops up at the same time so they sit about 1/4-1/2 inch lower so u never ride on the bag all the way empty. are u gonna be able to get the back to sit as low as the front? and wat book are we supposed to see? Quote Link to comment
freaky510 Posted January 17, 2011 Report Share Posted January 17, 2011 when aired out they have about 1/2" until fully compressed. No the front is lower :( but that might change. I am really not liking the way this is going together so it might be time to start cutting in to the body:eek:. i need about another 1 1/2" to have the bag sit ON the axle. with them in front they just not parallel to the top. FUCK why did the air shocks quit work arrrggggg I have a new found respect for all you fab guys this shit is hard with out all the cool tools all i got is a grinder and ban saw and for the book its "JUMP" by Scott M. Fisher ' Quote Link to comment
erichwaslike Posted February 9, 2011 Report Share Posted February 9, 2011 i can has update... update i must has it noaw! Quote Link to comment
freaky510 Posted February 9, 2011 Report Share Posted February 9, 2011 Well I have been working on it here and there tring to find a welder,had to get a new grinder.now i have all the tools i didnt have. I hope to have all the air baggs installed this weekend if not tonight, then to plumbing and wires.Had a few life issues come up but everything is taken care of now, WOOT I AM A FREE MAN !!!!! Quote Link to comment
izzo Posted February 9, 2011 Report Share Posted February 9, 2011 Get it done bitch tits. Quote Link to comment
freaky510 Posted February 10, 2011 Report Share Posted February 10, 2011 getting closer :blink: :unsure: :huh: :rolleyes: Quote Link to comment
freaky510 Posted February 15, 2011 Report Share Posted February 15, 2011 and closer Quote Link to comment
fisch Posted February 15, 2011 Report Share Posted February 15, 2011 It came in last week to our local library Dude how rad is that! And how rad are you for taking a pic of it for me! Thanks Freaky, you made my day!! Quote Link to comment
freaky510 Posted February 15, 2011 Report Share Posted February 15, 2011 Dude how rad is that! And how rad are you for taking a pic of it for me! Thanks Freaky, you made my day!! yea I order it in to our local libary. I for got to take a pic of the return card, it has been checked out 20+ times Quote Link to comment
fisch Posted February 15, 2011 Report Share Posted February 15, 2011 yea I order it in to our local libary. I for got to take a pic of the return card, it has been checked out 20+ times You have no idea how happy that news makes me! 20 times is great. Quote Link to comment
erichwaslike Posted February 15, 2011 Report Share Posted February 15, 2011 oh now i get it thats super cool fisch Quote Link to comment
freaky510 Posted February 15, 2011 Report Share Posted February 15, 2011 So i have spent this crapy cold ass day tring to figure out what this came out of. I cant figure it out help please Quote Link to comment
datto510 Posted February 15, 2011 Report Share Posted February 15, 2011 Who cares what it came out of. Its cool. Put it in the 411. :cool: Quote Link to comment
MikeRL411 Posted February 15, 2011 Report Share Posted February 15, 2011 Looks almost like the center console from some version of the 240SX. Quote Link to comment
freaky510 Posted February 17, 2011 Report Share Posted February 17, 2011 a few requested shots hhhmm sparks welding upside down was easier than i thought it was going to be Quote Link to comment
