Fostin510 Posted November 4 Report Posted November 4 Hello again. I came across a broken bolt inside one of the holes in my timing chain cover. It broke about an 1/8" below and it wasn't a clean brake. Tried to drill it out but the hole I drilled is too close to the threads in the cover. Any thoughts on a better approach to resolving this issue? Thanks Kevin Quote
datzenmike Posted November 4 Report Posted November 4 No threads in the cover. Better yet remove the timing cover and you should be able to get vice-grips on the broken stub. Quote
mklotz70 Posted November 4 Report Posted November 4 I thought this looked like an interesting way to get a tap out..... https://www.instagram.com/p/Dd4_j7Jkl0B/?img_index=1 Quote
Fostin510 Posted November 4 Author Report Posted November 4 Actually there are four bolt holes across the bottom of the cover. I guess my next question would be; If I can't remove it, do you think the oil pan leak at that location? Quote
iceman510 Posted November 4 Report Posted November 4 So you mean the oil pan attachment holes in the bottom of the timing cover? In the flange below the crankshaft seal in the picture? I will say-"yes it will possibly leak". Drill it out and helicoil it. Quote
Draker Posted November 4 Report Posted November 4 It will leak. I just tore down an engine with this issue, it leaked. Best way, small drill bit. Drill hole, slightly bigger, until it's out. If you're off center, drill it wide and helicoil it, or timesert. No doubt, it sucks. Lots of work.. for a small issue. Quote
datzenmike Posted November 4 Report Posted November 4 This factory L shaped strap at the rear of L20B oil pans would be easier. Make one for across the front of the oil pan and it will spread the clamping force of the other bolts. Use slightly longer bolts. Quote
banzai510(hainz) Posted Friday at 06:48 PM Report Posted Friday at 06:48 PM the 510 outlet has those oil pan rails and the good starters https://ermish-racing.com/engine-accessories Quote
