NicktheMillwright Posted November 1 Report Posted November 1 Good afternoon I just got my z24 apart on the stand. Pulled the crank and rods out. The bearings are tired, they need replacing. I mic'd the journals and found the rods are well within spec, but my mains are measuring a 2.3610 on all 5 mains. The reference chart tells me the rods are good, but how are my mains .200 larger than what every chart says it should be. When I compare my findings with rockauto, the diameters match up, and are in spec. Checking the FSM, nope, .200 out of spec. Where am I getting the error? Clearly the crank if fine but for my own curiosity. I plan of buying these bearing replacments https://www.rockauto.com/en/moreinfo.php?pk=6506595&cc=1210352&pt=5220&jsn=10&optionchoice=2-STD-0-1 Quote
datzenmike Posted November 2 Report Posted November 2 The chart is wrong, you're OK. My '84 720 FSM says the same error but I had crossed it out and put in 2.3599"-2.3604" which is part number 12207-U6001 for a standard set and is the same part as used in the L20B/Z20/Z22 engines. I fitted L20B main bearing in my Z24 engine. 1 Quote
NicktheMillwright Posted November 2 Author Report Posted November 2 Solid copy, thanks Mike. I was so confused that I double checked my mic with a gauge block. Exactly .200in lost to the wind seemed steep. Quote
NicktheMillwright Posted November 4 Author Report Posted November 4 Had some more time to finish measurments, and piston 3 is out of spec and scored enough where I cant reinstall it with confidence. I plan to have the cylinders all punched out .5 over and the block decked. What pistons should I throw in? I know the KA pistons fit just fine, but if you where me and had the opportunity to put new pistons in, what would you use? Quote
datzenmike Posted November 4 Report Posted November 4 Check the block for flatness but I wouldn't deck it unless damaged. 0.5mm over size KA24E pistons have a 2cm dish, almost a flattop. Used on a Z24 it would produce a compression of 9.62. The Z24 head and combustion chamber have three things going for it to reduce pinging or preignition. Hemispherical combustion chambers which are the most efficient and no corners or edges that produce hot spots. Dual spark plugs which shorten the burn time and thus shorten the ignition advance. Cross flow design with intake and exhaust on opposite sides. This keeps the hot exhaust ports well away from the cooler intake ports. The Z24 rod small end width is wider than the KA24E rods. Used on a KA piston there is less room to slide side to side to allow the rod big end to center on the crankshaft. Just check this before final assembly. Quote
NicktheMillwright Posted November 4 Author Report Posted November 4 Ive also read that I may need to cut reliefs for the valve? Maybe if the head/block needs to be decked How does the added compression affect drivability and starting day to day? Quote
datzenmike Posted November 5 Report Posted November 5 A good question. Only time the valves are open is as the piston approaches TDC on the exhaust stroke where the exhaust is closing and the intake just beginning to lift off the seat. Of both, the larger diameter intake valve would be closest to hit but it's closed and just beginning to open at 160 BTDC. I assume this is crankshaft degrees, so 80 at the cam. The smaller exhaust valve is already open but closing at 140 ATDC (70 at cam?) There is also the safety cushion of 0.012" valve clearance and the 1.2mm head gasket thickness. I guess use a compass and mark the cam sprocket at 160 before and 140 after. Use a straight edge across the combustion chamber and see where the edges of the valves are. If more than 1.2mm above then you are extending down into the very small piston dish. Time to assemble head to block with a blob of Playdough on the piston top and very carefully rotate through TDC. If there is interference don't force it or you may bend a valve. Otherwise measure the pinch point on the Playdough for valve/piston clearance. Not much dish... Quote
NicktheMillwright Posted November 5 Author Report Posted November 5 That I can do. This gives me something to think on. Thanks Mike A follow up question. From my research the KA24 and its variants from the 240's and hardbody share some minor differences. I want to know which KA24E pistons I should be looking for. It seems they may differ between early and late year hardbodies and 240's? I'm having a hard time finding concrete evidence and comparisons. Alternatively, the idea of keeping things simple is sort of growing on me, and just buying a set of these from Mizumo Auto is tempting. The expectation for this truck isn't to make a shit load of power. Quote
datzenmike Posted November 5 Report Posted November 5 The KA24E in the 240sx had a domed piston for just a couple of months before changing to the ones shown. The 240sx pistons were 'floating' on a bushing in the rod's small end so the piston pins are held in place from sliding sideways with C clips that fit in a groove in the piston. If using the Z24 rods they will simply be press fit. The pistons in the D21 Hardbody are press fit. You could use either as the Z24 rods are just the regular press fit. I believe you just heat the rod small end and quickly slip the pins and pistons together on the rods. these will work in 0.5mm oversize but no compression increase. As to a 1.5 point compression increase, this is very roughly, well on a good day, a 5% per point increase in power. On a 100 hp Z24 that's about 7 hp at the top end and less and less as the RPMs fall. On a stock engine that's not much but it's free and never goes out of tune. On any engine with a big cam, multi carburetors and headers it adds up. Quote
NicktheMillwright Posted November 5 Author Report Posted November 5 Thank you for the clarification Mike. This helps me narrow my search. Ill give it some time and think about what I want to do. I've never been after crazy house power numbers, not that a 7hp increase is massive. But you get what I mean. I apologize but I have another question. I keep seeing that Id have to swap the con rods to the KA rods, but when I dug around on spec sheets, it seems like, as you mention earlier, the only difference is the width on the small end of the con rod, the Z rods being wider. But I seem to recall somewhere on the internet that the diameter of the rods is also different? I'm getting confecting findings. Quote
datzenmike Posted November 5 Report Posted November 5 I don't think you would have to switch to the KA rods, the Z24 rods should work but for checking the width clearance. They can always be milled down for clearance. KA and Z24 rods. They have the same pin diameter and overall length. The bottom journal diameters are the same. The Z24 rods look heavier. Just for fun... Quote
NicktheMillwright Posted November 5 Author Report Posted November 5 Im sure that will buff out. I found these and these in a. I dont have any experience with ITM, but if its only pistons I need, then I can live with that. As you said, its effectively free. I use a 1990 240sx to find these pistons. Ill only order them after I confirm the head and block dont need to be decked. Quote
datzenmike Posted November 5 Report Posted November 5 A borrowed straight edge across the head in an X and a 0.004" feeler gauge is all you need. If a 0.004" gauge will fit under the straight edge at any point then the head needs milling. It's the same for the block. I would do this myself as I have a straight edge. A shop can do this but they like the work and you never know if it really needed it. Heads can warp from over heating, blocks rarely. Either surface must be exceedingly clean for best results sealing and longevity of the head gasket. One other thing is the Z24 has a problem with blowing head gaskets every 100k. Not true on the other Z20 and Z22. The preventative is once a year, on a cold engine, loosen ONE head bolt and re-torque directly to 60 ft. lbs. Then move to the next bolt in any order. With 9.6 compression you may have to run higher octane gas. Quote
