Rusty Fenders Posted October 28 Report Posted October 28 I have a 620 that currently has an L16 with a 280Z 5 speed and am planning to put in an L18. I want to get a new clutch cover and disk but am not sure what disk to get. Is the 280Z 5 speed transmission input shaft diameter and spline the same as for transmissions that came with 4 cylinder L engines? Should I get a friction disk for a 280Z and a clutch cover for the L16/L18? Also, where can I buy a new clutch cover for the L16/L18? I have searched but only seem to find 6 cylinder and roadster clutch parts. Thank you for any replies. Quote
datzenmike Posted October 28 Report Posted October 28 1/ The L16/18 uses a 200mm diameter pressure plate and clutch disc. The 280zx clutch is 225mm so it won't fit. 2/ All Datsun/Nissan transmission input splines are the same. Your L16 5 bolt flywheel and 200mm clutch will fit and work on the L18. Just get a replacement clutch disc and PP for the '73 620. Use a block of wood and 80 grit emery cloth and polish the flywheel to take the glaze off. If gouged have it machined smooth. Replace the pilot bushing in the end of the crankshaft. They go in dry, no lube and are cheap. A new one is good insurance against having to pull everything apart to replace later. Replace the release bearing. Again cheap insurance against having to pull the transmission later because it starts growling. Quote
banzai510(hainz) Posted October 28 Report Posted October 28 (edited) L16 and L18 is the same set up 200mm this is a good upgrade if you want a stronger pressure plate. as the stock L16 is like 350KG. If you plan on keeping this I would get a spare as the Nissan made Roadster 650 pressure playe and now these are NLA.. No longer made. its harder on the slave and master and soethimes they blow out cause the increase pressure so maybe get new master ans slave also https://www.ebay.com/itm/233202857988?fits=Model%3A2000|Make%3ADatsun&_skw=daiken+exedy+datsun+2000+clutch&itmmeta=01M61XT4WV8Q000PCJXH7R0YAP&hash=item364bf93804:g:f-4AAeSwa6ppgkVZ&itmprp=enc%3AAQALAAABACHNgUiiE%2FjQhlDTaMiAde9S0s42zRuXJ3K93jSQCwCZpIeaW%2BwN7lHiAruo2nfdwweOHyMR3joVIBVuIxt3qS4iNKNZhvlFeCtm3DYQ8NS%2B9HLrpXgiJWoITaigbaAVNg%2BzRRZaqZ7eNOW%2B1%2FqwxFmp%2BkPpMmvEAatP1BCLIGKYdyvtozrd5YNjJJtQ2%2BhR7mFP7oVUiYTq10ECZiqJTbXZGEET9mYKscrA4cnOEuQdCmA8XBLLM%2BnAVnRKqtPiVtv3NmtKgbZfkiQKxvGtsj%2Be6QqVrwLv1OVju%2FPQQW6bnh6jZjYnodlD0r%2BwZXdmERHucnD48ha%2BY0FuvTVOvVo%3D|tkp%3ABk9SR8rO6L2waA if you like the soft stock clutch then thats for your year model.. I cant find the stock exedy clucth number. If you look up parts for 620 alot of those trucks are the 225mm flywheel for a later 620 so dont get confussed. Rockauto list the Sachs and Luk models. the Exedy is japanese but I cant find the part number right now for yours. I got a stock one in my 521 and like it but its a stock motor and dont drive it hard. if you oder this uUPGRADED one i linked too please match it up and cheak the T/O bear to make sure the same.!!!!!!!!!!!!!!!!!! if your putting the L18 in thinking your getting a More powerful motor dont waist your time if your l16 is still good. I know Edited October 28 by banzai510(hainz) Quote
banzai510(hainz) Posted October 28 Report Posted October 28 this looks like it fits, only a suggestion L16 is a 200mm Im not a mind reader on what you actually have It says ASCO on the pressure plate up close which is AISIN which is a good company. https://www.ebay.com/itm/135255584829?fits=Year%3A1972|Model%3A620+Pickup|Make%3ADatsun&_skw=1972+datsun+620+clutch+kit+exedy+200mm&epid=74898809&itmmeta=01M62036BY035C711HPQ35QPHN&hash=item1f7ddc703d:g:tegAAeSwVVRqxQdr&itmprp=enc%3AAQALAAAA8CHNgUiiE%2FjQhlDTaMiAde8yaAblkOmQTrzZpYkNyxJwXpcwzNjr6unpMhZFjswk1sJQwdV6TQB4FF%2Bbr3sDIkHWt5tWduXWub3MY17SXZ2fuhaSFom%2F5RatgMvTxamAcQlJKpg%2Fgn6Ny0Dq3dKSDZH%2FH%2BHOTnWnpl7vzv5ths4xTTfkebPPXO2TVdU8C1O7xjLuiMZstQw%2FLqNNc3u0AjOUenPjImdIMVqSJwhQ1eZ8U1J7TQhhqoZtlwBcy4YRwyo1kCBSnbOaj0Z6YwxXpoqbdHz6wR04H0bp38GOvZAKrZ35wrhN7bg9PkHZu1cdvQ%3D%3D|tkp%3ABk9SR6LmjMCwaA Quote
datzenmike Posted October 28 Report Posted October 28 Generally the L16/18 do use the 200mm clutch EXCEPT the '74 620. The '74 620 uses a 5 bolt 225mm flywheel. Unique in every way and only this one year truck. All clutch masters are basically the same so weather 200mm, 225mm or 240mm, the master can handle it. If using an old used master, changing to a stiffer PP might might be enough to start it leaking but a new one, even one for a small 200mm PP, is fine. When it was said that the L16 was being changed to an L18, I assumed it would be with a much more common 200mm PP from a 610 or 710 car. Quote
banzai510(hainz) Posted October 29 Report Posted October 29 (edited) if he has a L16 in there already I lay money its a 200mm but Im not there and a Mind reader Edited October 29 by banzai510(hainz) Quote
datzenmike Posted October 29 Report Posted October 29 If an L16 then has to be 5 bolt mount to the crank. Five bolt flywheels only came with bolt pattern for 200mm clutch. Except that one year ('74) the five bolt crank L18s had special 225mm flywheels. Quote
Rusty Fenders Posted October 29 Author Report Posted October 29 Am I correct in assuming that the 200mm and 225mm dimensions refer to the outer diameter of the friction disk contact area and not the overall diameter of the flywheels? Quote
datzenmike Posted October 29 Report Posted October 29 Physically all L and Z series 4 and 6 cylinder flywheels are all the same dimensions. They are further divided into 5 and 6 bolt flywheels for mounting to the engine crankshaft. Two liters and higher displacement engines have the 6 bolt crankshafts. They do come in 200mm/ 225mm and 240mm bolt patterns to match the three clutch disc and PP dimensions available. 200mm and 225mm PPs use 6 mounting bolts. 240mm PPs have 9. The engine side of the flywheel can be either flat or scalloped to give a (roughly) 22 and 29 pound weight. Lighter weight ones tend to be on cars with four and six cylinders and the 'heavy' ones on four cylinder trucks. L16/18s are 200mm diameter clutches. 225mm flywheels are mostly used on truck and six cylinder cars. The 240mm PPs are used on 720 trucks from '83 with Z20 and Z24 engines and on D-21 trucks with Z24 and KA24 engines. Car KA24s use 225mm clutches. . Quote
banzai510(hainz) Posted October 30 Report Posted October 30 (edited) 22 hours ago, Rusty Fenders said: Am I correct in assuming that the 200mm and 225mm dimensions refer to the outer diameter of the friction disk contact area and not the overall diameter of the flywheels? Yes I believe all these will work. What makes you thinkyour clutch is bad? I know the 510/521 and maybe the 1st year 620 have the adjustable throw out arm for the slave cylinder. the 280zx has the cup pocket for the slave pushrod to fit into and its a differnet size alot shorter. so make sure the throw out arm is fully getting pushed into the slave. I found this https://www.311s.org/phpBB3/viewtopic.php?t=24841 says the daiken/exedy 06025 is the Roaster and will fit. Summit racing list one for sale nowhttps://www.summitracing.com/parts/exy-06025 06020 is the stock 510 and 521 and assume will fit the early 620 with a l16. I have this part in my 521,https://www.summitracing.com/search/part-type/clutch-kits?fr=part-type&ptr=clutch-kits&ptr_oos=1&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=Exedy 06020 then I remember daiken NSC581 the 600KG kit also https://www.ebay.com/itm/233202857988?_skw=exedy+clutch+kit+nsc581&itmmeta=01M67064YVB1NN4GJ5P5CPS6XJ&hash=item364bf93804:g:f-4AAeSwa6ppgkVZ&itmprp=enc%3AAQALAAAA4CHNgUiiE%2FjQhlDTaMiAde8kVZvYZVEgwSLvtEAsYtu1RxrAG%2BvAFYFHGrdTuAf5Qoj%2Bk%2FT%2Fvc1qxCNqHJDYi9dFrh7NcPg70oBFg2bc2DfF1U6imLFmiyetQvXfJy5mk5J09k0GBt%2FEUVWBpU8WzRgyB7K3vSl0Oll4zIPNuObeP44%2BUCnL8QeHlPHp5kUf4nmt1j%2BO%2FECtlLURFyjnaAIUIC84kqnCXCa9a18fSLcIe1GFpyUIHIHGkHpTZtKKI9ukytK7vTXNKXNZ%2Bpivs6OkJi8xAwS4ySRpDpOU5NmW|tkp%3ABk9SR9jPmOCxaA I dont get why the 2 parts numbers for the roadster the 06026(maybe this is a true 650kG pressure plate and the NSC581 was a later made 600KG plate. ANYBODY CHIME IN ON THIS BE GOOD TO KNOW, THE 06020 IS A STOCK 510/521 350KG CLUTCH AND i HAVE THIS. SEEN THESE CHEAPER ELSEWHERE https://www.ebay.com/itm/257803156650?_skw=EXEDY+06020+CLUTCH+KIT&epid=110172761&itmmeta=01M670Z1TJ9K413QYC3KWGP2G4&hash=item3c0643fcaa:g:CZIAAeSwIhZq3YC-&itmprp=enc%3AAQALAAAA4CHNgUiiE%2FjQhlDTaMiAde9ikjI4fjNlO2LUChHkCfaPH5sitBq3r0H81NFrRrEhbG0nl05YnqTYx%2FaeQXcHKvunF2urqna4fzpF1BH1KQucy5rpV058p%2FqmZtujfFjSpO5VICb%2FWwRSElj5tBEfSLAPDGXhmMObUnkV%2FexqMacLPIfrp2mtUz3ga7q4ze3761FzCeMI6TcIVl7cUID2kzVlcIDw%2FEojMyJmSiyJ4HuDzizUEcUts4tbG2FbsJf%2BdWlyhJJxkP%2BVM66icaSAecpBSElw15wCDjj81zqGTZzo|tkp%3ABk9SR_Cd_OCxaA Edited October 30 by banzai510(hainz) Quote
Draker Posted October 30 Report Posted October 30 (edited) 74 620 (L18) had a 225mm 5 bolt flywheel. Edited November 2 by Draker Quote
Draker Posted October 30 Report Posted October 30 You could just save some trouble and drop in an L20b with a 6 bolt 225 flywheel. Quote
banzai510(hainz) Posted October 30 Report Posted October 30 (edited) but he said L16 to a 18 year of this rig would help but since he said a L16 and I have to mind read this its a 72. Unless somebody had a later l20 and but a l16 in there Edited October 31 by banzai510(hainz) Quote
datzenmike Posted October 30 Report Posted October 30 He also has PL620 in his profile making this an L16 or L18. An L20B would be HL620. 1 Quote
