smelt240 Posted October 19 Report Posted October 19 I'd be really interested to hear from someone who has driven a car with this suspension setup installed. Quote
RoadRace Posted October 19 Report Posted October 19 ha - this is old school stuff. i can not verify 100%, but my car had the comp struts, rear shocks and rear sway bar - springs might have been these ones, but they might have been cut springs - can't recall. The rears were KYB shocks and they are still on the car, as is the rear sway bar. All springs and front struts/inserts have been replaced....but it rode like a race car, rattled and bounced - felt everything. fine for me, "your results may vary" Quote
smelt240 Posted October 19 Author Report Posted October 19 Nice. I need to find a decent front sway bar, then I think I have the entire front end figured out. Most of the bushings are solid under this thing too. Should be interesting. Quote
datzenmike Posted October 19 Report Posted October 19 Competition suspension parts are at the far end of the spectrum from stock. Absolutely zero thought is given for comfort so keep this in mind. You could end up with a car that's literally a pain to drive. Quote
smelt240 Posted October 20 Author Report Posted October 20 17 hours ago, datzenmike said: Competition suspension parts are at the far end of the spectrum from stock. Absolutely zero thought is given for comfort so keep this in mind. You could end up with a car that's literally a pain to drive. Yeah, this thing definitely wouldn't be a very doable daily driver.... Maybe it could 'somewhere', but not with the roads we have around here. In the past, I daily-drove an all-out drift car (S13) on the street, but that was before I got hurt... The dude I got the 510 off was building a race car for the street, and that's the direction we were hoping to take it. As I've tried to get more in-depth with this thing, I'm finding the stack of injuries I'm dealing with is making it a lot harder than I thought it would... I've got someone in mind that could keep going on it, and then drive it the way it was intended to be driven. I knew this would be a challenge to do another car in this shape, but didn't expect it to be quite as bad as it's been. I feel like the car might have ran me over last night, and all I did was 'not much'. The idea of just how hard it will be for me to start welding in floors and roll cages is kinda starting to hit home... Arrghh. Quote
smelt240 Posted November 6 Author Report Posted November 6 I was going through a box of parts... Found these. Now, the "competition" suspension was designed as a unit. In the listing for all the recommended parts, I see no mention of these being necessary. Most of the manuals that talk lowered suspension say you need these on lowered cars, to help prevent bump-steer. RoadRace, any chance you happen to remember needing/ not needing to install these on your car? Either way- Opening all these boxes again is kinda fun. Quote
datzenmike Posted November 6 Report Posted November 6 Bump steer is when one front tire drops into a dip or goes over a bump but the other side does not. A bump effectively and briefly shortens the tie rod length and this will cause the tire on that side to toe out and the car will pull to that side. Bad enough around town having the steering wheel suddenly pull but on the highway during spirited driving it's damn well scary. Bump steer varies with the amount of lowering. No one bump steer spacer covers every lowering amount. Yeah.... you do need them. This is for my 710 but 510 similar. At rest, the steering tie rod must be horizontal. When lowered the steering knuckle position remains the same but the other end at the idler arm or the pitman arm lowers with the body. To achieve being horizontal, spacers must be placed between the bottom of the strut tube and the steering knuckle to move the tie rod down to level. I used a spirit level and measured the heights at both ends of the tie rod and found the difference to be about 1/2". Being a Datsun owner (and too cheap to buy them) I simply made my own out of 1/4" scrap aluminum. Two on both sides lowered the tie rods level. Quote
RoadRace Posted November 6 Report Posted November 6 i needed them when i put 280ZX struts on my other dime. on my current dime, i have none, but i am putting the "bump-steered" steering arms on - which is a stock steering arm, bent up at the tie rod attachment points - this stuff is critical on a lowered car. as Mike has just explained, bump steer is the toe change as the wheel goes through the camber change curve. its critical on a lowered car because you are closer to the limit of the curve in the static state, and the toe change increases at the extremes of the curve (or vertical arc the wheel is travelling through) meaning as the car is at rest, a smaller amount of wheel travel will yield a more noticeable effect....putting the spacers on relocates the tie rod/steering arm further back into the 'comfort zone' of the camber change curve, making the car more predictable to drive, 1 Quote
smelt240 Posted November 6 Author Report Posted November 6 OK, I guess it's good that I have them then. These would be pretty easy to make, but it'll save a few hours not having to. Here's how this thing sits on the entire competition suspension kit, sans motor and transmission: 1 Quote
smelt240 Posted November 6 Author Report Posted November 6 20" fronts on 13" wheels, the rears are 15x8 SSR meshies with 195/55/15's. Quote
datzenmike Posted November 7 Report Posted November 7 15 hours ago, smelt240 said: OK, I guess it's good that I have them then. These would be pretty easy to make, but it'll save a few hours not having to. Here's how this thing sits on the entire competition suspension kit, sans motor and transmission: Looks pretty high. Get the drive train in and back to final weight, then measure the tie rod angles and buy the correct thickness bump steer spacers, if needed. Once done the toe must be set. Lowering the rear messes with the wheel camber also. Quote
smelt240 Posted November 7 Author Report Posted November 7 6 minutes ago, datzenmike said: Looks pretty high. Get the drive train in and back to final weight, then measure the tie rod angles and buy the correct thickness bump steer spacers, if needed. Once done the toe must be set. Lowering the rear messes with the wheel camber also. I found two other sets of almost finished home-built spacers in the shed last night. 1/2" and 3/4". Plus a nice assortment of wheel spacers. If the weather holds, this thing might actually get mocked up before snow flies... I'll get some better pics of the stance once this rain stops. It's lower than it looks. Those front slicks are TINY, so the wheel arch looks giant. Plus, I have a feeling the opening might not be totally stock on the glass fenders. Something looks 'different' to me. 1 Quote
Rustbin Posted November 7 Report Posted November 7 The fenders look stock to me, but I think it's the small wheels and lack of engine weight that makes the arches look that huge. I have a set of 13" aluminum slots but will probably never run them for lack of tires. Quote
smelt240 Posted November 8 Author Report Posted November 8 15 hours ago, Rustbin said: The fenders look stock to me, but I think it's the small wheels and lack of engine weight that makes the arches look that huge. I have a set of 13" aluminum slots but will probably never run them for lack of tires. I had an all-stock 73 2dr a while back, and while we were swapping tires around when it got sold, we stuck these 13's on there. The fronts were tucked deeper, and just seemed 'bigger around' on that car. I have a feeling that this suspension setup maybe has a bit wider track width? I've got a set of stock struts sitting beside the car now. The competition struts are definitely shorter with much shorter springs, but without pulling the brakes off- I can't really see any difference in the spindle geometry. I was hoping to find some 13" tires that didn't cost $300 apiece... Then I got disappointed. 1 Quote
