TheGlueKing Posted October 18 Report Posted October 18 1987 nissan d21 2wd z24i weber 38/38 swapped heya, im lookin for parts numbers to do a proper distributor swap for my z24i motor. i have a weber 38/38 and no matter how i mess with it i cant get it to run just right. so im guessing i need to finish the lobotomy and cut the distributor. i feel lost trying to find the right parts. ive read i need a distributor and maybe a oil pump drive shaft (maybe even a different pump) but i cant find any distributors that are factory or clearly replacements/remans. (idk how to move the screenshot at top) this is the closest ive found to what i need but i have no clue if its even close. im lost, im hoping i can get a hand 🙂 Quote
datzenmike Posted October 20 Report Posted October 20 The D21 uses a CAS (cam angle sensor or maybe crank angle sensor?) to help the EFI set the advance. Not too sure how the ignition will work with the EFI disabled and a carburetor on there. You want an '83-'86 720 distributor and the drive spindle below it that also turns the oil pump. The 720 distributor will have a vacuum advance that can be connected up to the Weber. The distributor will have a power wire... connect to ignition or the positive terminal of one the coils. The other two wires on the distributor connect to the negative terminals of the two coils. If there is a fourth wire just leave disconnected. Quote
Stinky Posted October 22 Report Posted October 22 If you do a search....this has been covered 3-5x. If you do it right....it will work just fine. Quote
