PsychoNaut04 Posted October 3 Report Posted October 3 Was driving on the highway and heard ad odd noise. Suddenly it escalated to a rattling noise. Any advice? It used to make a loud whining noise prior to giving out. And currently im able to change gears with no resistance https://imgur.com/a/l6HXgsd Quote
datzenmike Posted October 3 Report Posted October 3 Most common failure point on the FS5W71B is the front countershaft bearing. Gets noisier over time, usually in all gears but fourth. If not replaced, the bearing comes apart and can damage the front cover or the transmission case. Not much you can do from the outside. Take the fill bung out and check the oil level. You should be able to reach in with a finger and touch the oil if full. If low, top it up, it may quiet down but the damage may already be done. Drain the oil and inspect the drain bung which has a magnet on it that collects ferrous metals. Check the oil for suspended metal particles, if oil is milky that's water that got in. This one has a piece of bearing cage on it. I've pulled one that had ball bearings on it. This is a front counter bearing that has failed. Likely can be saved by replacing it. Quote
PsychoNaut04 Posted October 3 Author Report Posted October 3 9 minutes ago, datzenmike said: Most common failure point on the FS5W71B is the front countershaft bearing. Gets noisier over time, usually in all gears but fourth. If not replaced, the bearing comes apart and can damage the front cover or the transmission case. Not much you can do from the outside. Take the fill bung out and check the oil level. You should be able to reach in with a finger and touch the oil if full. If low, top it up, it may quiet down but the damage may already be done. Drain the oil and inspect the drain bung which has a magnet on it that collects ferrous metals. Check the oil for suspended metal particles, if oil is milky that's water that got in. This one has a piece of bearing cage on it. I've pulled one that had ball bearings on it. This is a front counter bearing that has failed. Likely can be saved by replacing it. Awesome. Thank you Mike. I used to get a sort of turbine noise. And before changing gears it used to make a unique sound. I know there was something off about it. I think it may be bearings. Ill drain the oil today and check. Quote
datzenmike Posted October 3 Report Posted October 3 Check oil level first. If low or empty that's the problem. Topping it up might, I say might, quiet it. It should hold two liters or close to two US quarts of oil. I drained one that had what looked like thick silver paint in it. It was the bearing chewing up the case and two ball bearings came out with it. Quote
PsychoNaut04 Posted October 3 Author Report Posted October 3 1 hour ago, datzenmike said: Check oil level first. If low or empty that's the problem. Topping it up might, I say might, quiet it. It should hold two liters or close to two US quarts of oil. I drained one that had what looked like thick silver paint in it. It was the bearing chewing up the case and two ball bearings came out with it. I remember I did the oil change on my trans not long ago. The oil did seem muddy. So ill check it today. Honestly, i feel the bearing is the issue. Ill confirm. Quote
ElliotV Posted October 7 Report Posted October 7 On 10/3/2026 at 8:21 AM, PsychoNaut04 said: Awesome. Thank you Mike. I used to get a sort of turbine noise. And before changing gears it used to make a unique sound. I know there was something off about it. I think it may be bearings. Ill drain the oil today and check. That turbine/howling noise is the front housing getting eaten because your gears are moving. Mine did the same thing before I rebuilt it. My center countershaft bearing went out and the balls remained, if they didn't center perfectly the shaft would move and the gears were eating the aluminum housing. bad bearing worn into housing Quote
PsychoNaut04 Posted October 10 Author Report Posted October 10 On 10/7/2026 at 8:10 AM, ElliotV said: That turbine/howling noise is the front housing getting eaten because your gears are moving. Mine did the same thing before I rebuilt it. My center countershaft bearing went out and the balls remained, if they didn't center perfectly the shaft would move and the gears were eating the aluminum housing. bad bearing worn into housing Is this something I can fix myself? I’ve been reaching out to shops and it’s around 1k for labour. Quote
datzenmike Posted October 10 Report Posted October 10 Drain transmission and remove from vehicle. Inside the front 'bell' are 5 bolts that hold the front cover on. Remove cover bolts and strike the clutch arm pivot ball using a socket extension to jar the cover plate loose. Hitting the long 'nose' will only snap it off. Remove and save the shim from in front of the (smaller) counter bearing. Remove snap ring from in front of the main shaft (larger) bearing. The transmission has front and rear aluminum cases which sandwich a steel adapter plate that holds all the gears. There are 10? through bolts that clamp the cases to the adapter plate. Lightly hammer the front case forward and off the two front bearings. Hold onto the rear case and avoid it separating from the adapter plate. You now have access to the (smaller) counter bearing... Use a gear puller to remove. Hammer a new one on using a suitable diameter piece of pipe against the inner race. Assembly is the reverse of taking apart. The '84 should have the 56mm counter bearing, this was changed to 62mm for the '85 model year. The 56mm counter bearing is Part # 32219-E9000 Quote
PsychoNaut04 Posted October 10 Author Report Posted October 10 32 minutes ago, datzenmike said: Drain transmission and remove from vehicle. Inside the front 'bell' are 5 bolts that hold the front cover on. Remove cover bolts and strike the clutch arm pivot ball using a socket extension to jar the cover plate loose. Hitting the long 'nose' will only snap it off. Remove and save the shim from in front of the (smaller) counter bearing. Remove snap ring from in front of the main shaft (larger) bearing. The transmission has front and rear aluminum cases which sandwich a steel adapter plate that holds all the gears. There are 10? through bolts that clamp the cases to the adapter plate. Lightly hammer the front case forward and off the two front bearings. Hold onto the rear case and avoid it separating from the adapter plate. You now have access to the (smaller) counter bearing... Use a gear puller to remove. Hammer a new one on using a suitable diameter piece of pipe against the inner race. Assembly is the reverse of taking apart. The '84 should have the 56mm counter bearing, this was changed to 62mm for the '85 model year. The 56mm counter bearing is Part # 32219-E9000 Thank you! I worked on the engine myself, this shouldn’t be too bad then 😅 Quote
ElliotV Posted October 12 Report Posted October 12 Gear and bearing puller plus massive 3 jaw puller, a buddy, and a good adjustable wrench or set of large metric wrenches, Hammer and punch, plus some t40 bits and snap ring pliers are all you really need other than normal tools. Quote
datzenmike Posted October 12 Report Posted October 12 I've pulled front cases off in a wrecking yard in about 10 min. using only a 12mm and a 14mm ratchet and socket or maybe the front cover bolts and the adapter bolts are both 14mm? A long screwdriver to pick the snap ring loose. The counter bearing I changed on my 710 I did need a puller, no way around that. Had to grind the tips down thinner to reach behind the bearing. New bearing is hammered on using a piece of pipe the same diameter as the inner race. Quote
PsychoNaut04 Posted November 1 Author Report Posted November 1 On 10/12/2026 at 6:20 AM, datzenmike said: I've pulled front cases off in a wrecking yard in about 10 min. using only a 12mm and a 14mm ratchet and socket or maybe the front cover bolts and the adapter bolts are both 14mm? A long screwdriver to pick the snap ring loose. The counter bearing I changed on my 710 I did need a puller, no way around that. Had to grind the tips down thinner to reach behind the bearing. New bearing is hammered on using a piece of pipe the same diameter as the inner race. I have an update. I don’t know how it happened but I ran the transmission with no oil. I drained the little bit it had left and found this. i finally brought the transmission down and took a look at the first bearing. https://imgur.com/a/M983bre Quote
datzenmike Posted November 2 Report Posted November 2 Only way the oil can be low is a leak. The rear seal is the most common though there is one at the front. Look for wetness on the driveshaft. Yes that input main bearing is toast. Replace it and the counter bearing below it, hope for the best. Quote
PsychoNaut04 Posted November 2 Author Report Posted November 2 9 minutes ago, datzenmike said: Only way the oil can be low is a leak. The rear seal is the most common though there is one at the front. Look for wetness on the driveshaft. Yes that input main bearing is toast. Replace it and the counter bearing below it, hope for the best. You know, I realized the driveshaft was actually oily. That’s probably where it leaked. Is it easy to replace that seal? im also tempted to get it serviced but it would be at least $1k Quote
datzenmike Posted November 2 Report Posted November 2 Pry the old seal out with a screwdriver. Place the new one and drive in holding a large socket or block of wood over it so you don't damage it. Use a wooden dowel and tap all the way in till seated. Be sure to grease the seal lips so it doesn't start up on a dry surface. Quote
PsychoNaut04 Posted November 2 Author Report Posted November 2 1 minute ago, datzenmike said: Pry the old seal out with a screwdriver. Place the new one and drive in holding a large socket or block of wood over it so you don't damage it. Use a wooden dowel and tap all the way in till seated. Be sure to grease the seal lips so it doesn't start up on a dry surface. Thank you. I’ll do that Quote
