Wheels (15x6) and Tires Question
I have a question about whether Coddington 61B Smoothie Series Gloss Black Wheels 15x6 will fit problem free on my 521. (I don't know much about sizing--or cars.) I don't want to have to modify anything just to put new wheels on. The center bore is 108 mm (4.25 in), backspacing 3.63, offset +3.00 mm. My 521 has 3" lowering blocks and currently has 15" wheels and 205/65R15 tires. There is some rubbing at the front on sharp turns, so a smaller tire would be good.
1. Will these wheels fit without mods?
2. What size tire do you suggest?  175/60R15 and 185/60R15 are two that come up on AI searches, but AI will be the death of us all, so I want a human opinion. Happy driving.
  • Replies 3
The new rims are +3mm which isn't really much, about 1/10". This means the new 6" wide rim is almost centered on the WMS. A 175/60R15 is 6.9" wide so divide in half = 3.45 or round to 3.5". Measure out from the WMS and see if 3.5" rubs the fender opening. If there is lots of room you might go to a wider tire
I went with 185/60. I could have probably gone wider/lower, but I didn't want to risk rubbing or have a rough ride just for looks. The car feels much better.
