Yeager-Meister Posted September 11 Report Posted September 11 Hey guys first time datsun owner here. I recently got a 1968 520 truck, and while I get it running I figure this is a good place to document it. In my experience niche forums are really cool places and a great for advice. what makes the truck special? it doesnt have a datsun engine anymore, the previous owner swapped in a 2.0 pinto engine and 4 speed transmission. otherwise it seems mostly stock. it spent its life in california and had been sitting since 1983 so the rust isnt that bad. so far Ive been having issues getting the replacement clutch master cylinder to seal with the old hard line and getting the brake drums off. but after new plug wires a timing belt the engine is running. I look forward to seeing you guys on the road! 4 Quote
banzai510(hainz) Posted September 23 Report Posted September 23 be honest I like the Pinto motor. will be better!!!!!!!!!! early Datsun are SAE sizes on brake lines body bolts and the early engines. so I might assume the bDatsun brake line is going to a metric something. I dont know Pinto trans if they use a slave cylinder or is a Cable clutch like a German Ford Capri. But since you said. rereading I assume your saying the brake master and the hardline the screws in ???? At the top.(not underneath the car by the trans/slave cylinder Yes one has to be careful as I almost x thread and I alwasy use antiseize on there. I assume getting the brake drums off your pulling the cap wheel bearing and nut ?????? If runs start in gear and maybe the brakeshoes are stuck on drum. 520 and datsun 521 stuff is close to the same Quote
Yeager-Meister Posted November 4 Author Report Posted November 4 So its been a while. here are some of the pictures so far. I replaced all the wheel cylinders and now I have brake pressure. Muffler was clogged so I cut it off and now it revs out and runs just fine. ordered an aluminum radiator from ebay so I just need to put a new water pump and reweld the thermostat housing at the right angle. also ordered 185/75 tires. I would get the sending unit but I have heard a 240/280 will work with modification? I took it for a test drive with the old leaky radiator and water pump and the speedometer was all over the place, it also jumps around at idle too. 2 Quote
smelt240 Posted November 4 Report Posted November 4 Cool truck!!! Makes me really miss my 411SSS..... Those Pinto motors had a crazy following in the mud racing circuits around here back in the day. I bet there's still hotrod parts everywhere. Those things were firebreathers when they built 'em right. Wanna trade brake drum issues with me? Hint: You don't. Quote
Yeager-Meister Posted November 5 Author Report Posted November 5 the original owner was very fond of "customizing" his vehicles. It was the original slave cylinder on the pinto 4 speed which never was optioned with a hydraulic clutch. i was working on the wiring today and by replacing the wiring from the fusebox to the brake switch I got the brake lights to work. Also the headlights started working but the switch is crusty or something because it doesnt work all the time. 1 Quote
datzenmike Posted November 5 Report Posted November 5 On the headlight, try turning on and off a few dozen times to polish the contacts. Left all winter my horn would do this. Use is what keeps the contacts clean. Quote
banzai510(hainz) Posted November 5 Report Posted November 5 I would mount the coil back to the fender. the radiator? is that a Datsun rad? in there? I like the Patinas of the truck as it is paint rims white and run the small whitewalls that salve system and style work I just keep using it. Remeber the early thrucks are all SAE threads on everything. not metric Quote
datzenmike Posted November 5 Report Posted November 5 Was thinking the same thing but if that's a Ford coil they are used to the engine vibration. I always thought Datsun mounting on the fender was weird but I got over it. Quote
Yeager-Meister Posted November 6 Author Report Posted November 6 I honestly have no idea what the original radiator is, it has the both spouts on the same side which is not characteristic of the datsun nor pinto. consequently the thermostat housing was cut and welded to face the other way so I'll need to reweld that the right way. I might relocate the coil because power currently runs from the ballast resistor on the firewall across the top of the engine to get the the coil. tires are supposed to arrive tomorrow so Ill mount and balance them next week, probably going to paint the rims black or grey Quote
datzenmike Posted November 6 Report Posted November 6 Top tank looks exactly like the early 510 rad, later ones had the top hose over on the left. 521s similar? Quote
Yeager-Meister Posted November 6 Author Report Posted November 6 its kinda annoying to upload pics but it wasn't held in place by the welded nuts, rather with extra holes drilled through the support Quote
Yeager-Meister Posted November 8 Author Report Posted November 8 I took the fuse block out and cleaned all the terminals, didn't make a difference. of the wires that go to the wiper motor, only one is intact. also working on a thermostat housing Quote
datzenmike Posted November 9 Report Posted November 9 Make sure there is a good ground connection to the block and the body, specially the body. The drive train is isolated from the body by rubber mounts. The shocks, the leaf springs, the cab and box. Quote
Yeager-Meister Posted November 9 Author Report Posted November 9 using a test light in reverse the block, body panels, cab all have ground. One horn works but the other doesnt at all I even used it directly against the battery post. Just cleaned up all the terminals inside the steering column and adjusted the switch housing forward and now the horn works sometimes and the turn signals work after I cleaned the bulb sockets. Quote
datzenmike Posted November 9 Report Posted November 9 Power the horn and give it a good solid whack on something or hit it good. If it's the horn button do the same as the lights. Tap the horn button a few dozen times to polish the contacts. Quote
Yeager-Meister Posted November 9 Author Report Posted November 9 is there a particular way to disassemble the horn button? I unscrewed the three screws to slide the switch housing down and I sanded the little pickup arm and the ring it slides against but idk how to get to the button inside. Quote
Yeager-Meister Posted Tuesday at 10:35 PM Author Report Posted Tuesday at 10:35 PM just got the radiator today, looks like it will fit in the holes already in the support but the bottom spout points into the frame so Im not sure how I can connect it to my waterpump. took the horn out and tired hitting it cleaning it but still wont work Quote
datzenmike Posted Tuesday at 11:47 PM Report Posted Tuesday at 11:47 PM A friend tore his lower rad connection off his Toyota truck by pulling on the hose to remove it. It's only held on by lead solder. No problem I says. I took the rad home, heated and wiped the excess solder off the rad and the fitting and cleaned straightened and tinned both. Installed fitting and crimped it to just barely fit in place, heated and run solder around the seam. That was 20 years ago. Quote
NC85ST Posted Wednesday at 02:41 PM Report Posted Wednesday at 02:41 PM 16 hours ago, Yeager-Meister said: the bottom spout points into the frame Is that an aluminum radiator? That could pose a slight problem. Quote
Yeager-Meister Posted Wednesday at 06:58 PM Author Report Posted Wednesday at 06:58 PM yeah chinese aluminum radiator Quote
wayno Posted Wednesday at 09:15 PM Report Posted Wednesday at 09:15 PM Take your old radiator to a radiator shop and have them fix it, maybe a new core. Quote
Yeager-Meister Posted Wednesday at 10:26 PM Author Report Posted Wednesday at 10:26 PM the radiator that came with it had a lot of damage and leaked a lot. It wasnt original to the truck or the pinto and it didnt mount with the original bolts on the core support, so I dont want to reuse it Quote
