Changing Shifter
Schroeder6th
Need a little help:
have curved back shifter in car and have a straight up shifter that i wish to install.
Looks simple enuf, wrench slot at bottom of shifter/bolt on bottom of barrel. losened bottom bolt, notta. nothing moves? and don't want to force anything until i have some insight.
Thanks
  • Replies 11
Wow that's a fairly rare tranny. It (I think) uses the removable L series bell from an early 240z tranny, or IS an early 240Z tranny. The Roadster tranny was used in them.
Here is a Roadster 5spd and it does have the A type shifter known as the 'monkey motion'.
http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transearlycloseratioroadster_box_.jpg[/img]"]transearlycloseratioroadster_box_.jpg
I could be wrong, but a 5 speed option wasn't available on a Z car (in north Am.) until the '77 280z. (FS5W71B) Other 5 speeds were available from overseas where they were an option and could be imported by dealers. Again I don't have the exact story and could be, and likely are, incorrect. Roadster boxes with L bells attached were used. These were called FS5C71B if overdrive and F5C71B if 1 to1 5th gear.
FS5C71B Competition Box:
Standard
1st - 2.957, 2nd - 1.855, 3rd - 1.310, 4th - 1.00, 5th - 0.852, Rev - 2.922
Middle close - Option 1
1st - 2.678, 2nd - 1.704, 3rd - 1.262, 4th - 1.00, 5th - 0.852, Rev - 2.922
Ultra close - Option 2
1st - 1.858, 2nd - 1.388, 3rd - 1.217, 4th - 1.00, 5th - 0.852, Rev - 2.922
Option 3 ???
1st - 2.554, 2nd - 1.758, 3rd - 1.271, 4th - 1.00, 5th - 0.850, Rev - 2.922
F5C71B Race or Competition Box with 5th gear 1 to 1 ratio:
Race Transmission #1: #32010-N3220
1st-2.818, 2nd-1.973, 3rd-1.470, 4th-1.192, 5th-1.00
Race Transmission #2: #32010-N3221
1st-2.348, 2nd-1/601, 3rd-1.296, 4th-1.138, 5th-1.00
Race Transmission #3: #32010-N3222
1st-2.192, 2nd-1.601, 3rd-1.470, 4th-1.138, 5th-1.00
Rally Transmission: #32010-N3201
1st-3.321, 2nd-2.270, 3rd-1.601, 4th-1.240, 5th-1.00
I wouldn't rush out and buy one but if you have one, and it looks like this one, I would hang onto it till you know exactly what you have.
Note that the bell is removable. I'll check, but I believe there was a need for a good strong 5spd back then and the FS5W63L dogleg just wouldn't cut it. Nissan (I believe) subbed an L bell onto the roadster tranny and used that.
Again, if I have this wrong and anyone knows better I would welcome any corrections in what little I know about these trannys.
Edited by datzenmike
yea i dont need one but the guy that does maintaince for the aptartments that i live in has a bunch of ole z parts says both 5 speeds came out of 71 or 72's and they are for sure 5 speeds, has a few radiators and an engine as well doesnt know what any of its worth but will practicly give it to me im sure.
