JoeVR Posted July 31 Report Posted July 31 I have a 1982 Datsun 720 that needs a new engine. What other Nissan or Datsun engines can be a direct bolt in - or at least with minimal modifications? I think it might be cheaper to find a running engine somewhere and drop it in instead of rebuilding my current one. It looks like the Z motor mounts are all the same. Could I use a newer Z motor, remove the fuel injection, and put my carb and intake on? Any motors that I should stay away from - or engines/years that I should look for specifically? I currently have a 1982 Datsun gas extended cab, 4x4, 5spd. Thanks! Quote
NC85ST Posted July 31 Report Posted July 31 The easiest swap would be a z24. I believe that they started using those starting in ‘83. You can use the z24i but there some things that have to be changed in order to stick with the carburetor. I’m not sure of what all needs to be changed aside from the carburetor and intake. Of course the problem is finding a used engine in good shape. 1 Quote
datzenmike Posted July 31 Report Posted July 31 If you want 'drop in' do not try to fit any other engine. Yes a Z24(S) carburetor engine is as drop in as it comes. You have all the parts needed on your old Z24 to convert a Z24i to carburetor. They are... 1/ the distributor 2/ the oil pump/distributor drive spindle 3/ intake and carburetor. The '81-'82 Z22 from a truck should drop in. The Z20E from an '80-'81 or Z22E from an '82-'83 S110 200sx engine should work if you change the same 3 items as converting a Z24i. The Z20(S) '82 A10 (HL510) is an 8 spark plug engine and should literally drop in. I would avoid the '83-'86 720 Z20(S) engine as it is high compression and has a knock sensor but your truck won't have the wiring and electronics to support it and it will ping like crazy. In All Cases automatic or manual, you can swap your Z24 flywheel and clutch assembly onto the donor engine. This will avoid any problems with miss matching the release bearing collar. If you have an automatic you will need to remove the clip on torque converter pilot from the end of the crankshaft and pop a new pilot bushing into the end of the crankshaft. Pilot converter... This is me removing a pilot bushing, but you get the idea. They are soft so use a block of wood to protect it when you hammer it in. Quote
SAAN455 Posted July 31 Report Posted July 31 Well I am from KSA my 720 is 82 crewcab 4WD came stock with L18 and 4 speed we didint have the Z 22 or 24 in 720s only in D21 carbed to 2004! Quote
datzenmike Posted August 1 Report Posted August 1 15 hours ago, SAAN455 said: Well I am from KSA my 720 is 82 crewcab 4WD came stock with L18 and 4 speed we didint have the Z 22 or 24 in 720s only in D21 carbed to 2004! My reply was for JoeVR. Not familiar with KSA but aware L series were used in the 720, probably points ignition and no emissions controls and double cabs were common. Quote
SAAN455 Posted August 1 Report Posted August 1 Points ignition : yes emissions? NO no king cab 4WD are very rare single and double cabs everywhere AC not so much 5speed came in 85 as an option https://kommodo.ai/i/Zkv6ngsck024ddpXKgZj https://kommodo.ai/i/EJlnsWFMRNZnR7rikC56 sorry about the bad photos the car needs a paint job but its not rusty Quote
datzenmike Posted August 1 Report Posted August 1 This is someone's discussion about an engine swap. If you want, start something in the 720 Trucks section... https://ratsun.net/forum/53-720/ Over on the far right is a blue rectangle that says Start New Topic. Click on that and it's all yours. Tell us anything about your truck and your plans. Pictures are always welcome. Quote
SAAN455 Posted August 1 Report Posted August 1 2 hours ago, datzenmike said: This is someone's discussion about an engine swap. If you want, start something in the 720 Trucks section... https://ratsun.net/forum/53-720/ Over on the far right is a blue rectangle that says Start New Topic. Click on that and it's all yours. Tell us anything about your truck and your plans. Pictures are always welcome. Thanks Mike well do Quote
bottomwatcher Posted August 2 Report Posted August 2 15 hours ago, SAAN455 said: Points ignition : yes emissions? NO no king cab 4WD are very rare single and double cabs everywhere AC not so much 5speed came in 85 as an option https://kommodo.ai/i/Zkv6ngsck024ddpXKgZj https://kommodo.ai/i/EJlnsWFMRNZnR7rikC56 sorry about the bad photos the car needs a paint job but its not rusty I love the bed and tailgate! Quote
JoeVR Posted September 2 Author Report Posted September 2 Thanks, guys, for all this help. And I loved the side track to the crew cab - I'd never seen that one before. I am trying to figure out right now if I really need a new engine, or if the previous owner (who claimed he had just re-done the timing chain) was only a few teeth off. I may have to tear it down to figure it out, but that's all part of the adventure. Thanks everyone. I appreciate the ideas and advice. Quote
