ae86 ka24de can/am box
having hard time turning on my can/am box. had the car running and idle and had all 3 light working before.
now i have 2 outta 3 light working on can/am box *red light* . dont hear the the fuel pump prime. idk if i have a sort or do i need buy fuel pump relay.
here a few pics with a volt tester . any info will help. thank
b05e6fc00686e865d7154ef978f8e979a97cf3a3
738171bd79c1d41b7efffa2abd11afc5365aeb72
  • Replies 4
Is the ECU signaling the relay?
You can pull the relay and test it off of the box or swap them around and see if the problem moves with the relay.
  • 4 weeks later...
ecu getting signal , relays is also good too. i use 12v battery hearing it clicking. i also change wire too the fuel pump *14 gauge wire*. still not turning on.
should i put a toggle switch to power up the fuel pump separate from the cam/am box?
I dont think you need 14gauge.
why dont you ck for power to the fuel pump from can am box.
this is not that hard.
I think that a lame move .
the relays should power it up
