Roy hunter Posted June 30 Report Posted June 30 looking for used/new parts in the LA area for my 71 pick up. 521. driver side knuckle and control arms are loose Quote
datzenmike Posted June 30 Report Posted June 30 Steering knuckle? Two bolts hold it to the bottom of the spindle, if loose, tighten them. If it's at the steering ball joint it needs to be replaced. Better check all the steering ball joints. If you mean the spindle knuckle then the king pins likely need replacing. Upper and lower control arms?? Probably bushings and seals worn out. 1 Quote
Roy hunter Posted June 30 Author Report Posted June 30 okay thank you, control arms are easy to find but i’m having know luck on the rest Quote
datzenmike Posted June 30 Report Posted June 30 The rest???? King pins? Try E bay but they are getting rare. Quote
