‘85 4x4 vibrates horribly under load
I have been tracking down a strange and concerning vibration coming from my truck under load.
1985 720 4x4 King Cab
The vibration appears to happen in every gear under load, however it is barely/not noticeable in 1st/2nd, definitely felt in 3rd gear, unmistakable in 4th and horribly annoying and terrible sounding in 5th.
It sounds and feels like the cab is connected to a large massage-gun.
The vibration and accompanying noise
completely stops if I let off the gas pedal, even at 80+ mph the truck will coast along smooth as butter in or out of gear.
I’ve inspected all the joints in my driveshaft and around my t-case, nothing jumps out as looking problematic. main, front and rear driveshaft all have zero rotational or side-to-side play. (front driveshaft has like a micrometer of side-to-side play but this has been the case for years with no issue)
Motor mounts look good, and excessive vibration doesn’t happen when revving out to 5k in neutral.
Transmission mount looks and feels new
Truck does not have a carrier bearing from factory
All diff/tcase/transmission fluid changed less than 20k miles ago
Symptoms present regardless of speed, but worsens in higher gear + more gas applied.
No clue what could’ve caused it, I parked a smooth driving truck and 30 minutes later when I went to drive I was having this issue.
Any suggestions would be greatly appreciated! I feel like i’ve checked the obvious stuff and want to make sure i’m not missing something.
  • Replies 31
Posted (edited)
Back in 2017.My truck was shaking real bad and making a noise.Was not driving good at high speed.I could not figure where the noise was coming  from.Took to muffler shop and they said it was from the transmission.So I took to transmission shop.They put on a lift where they could  drive it in the air on the lift and and see from under it where the noise was coming from.The yoke was bad.The U joints were replaced at first but problem was still there. He called another local shop and they had a new yoke for 135.Here is the original Nissan yoke.See the scorn marks on it.That was what was causing it to vibrate.That was 9 years ago.Could be your problem or not.Mine is a 85 4x4.I did post these pictures years ago on here.I still have the receipt on the yoke.I still have old yoke.
Edited by Thomas Perkins
For a 1985 Nissan 720 4x4 (equipped with the FS5W71B 5-speed transmission), the transmission and transfer case output typically use a 22/24-spline (24 splines with 2 skipped/blind teeth) or 30-spline slip yoke. The mating universal joint is commonly a 1310 or 1330 series.Because Nissan made a mid-production update in 1983 to accommodate larger engines and differentials, the correct size for your specific truck depends on the exact build date.The best way to determine your yoke size before ordering replacements is to confirm the following specifications:Spline Count: Count the splines on your existing transmission output shaft.U-Joint Style: Measure your universal joint to see if you have a 1.063" cap diameter for a 1310 series or a 1.063" cap with a wider 3.625" overall width for a 1330 series.Hub/Barrel OD: Measure the outside diameter of the cylindrical barrel (where it slides into the transmission seal). It is usually around 1.375" for a standard Nissan style.You can find replacement yokes and cross-reference parts through specialized drivetrain suppliers like Action Machine Inc or Fort Wayne Clutch.To ensure you get the exact right fit, could you tell me:Is your truck equipped with the manual or automatic transmission?Have you checked if it was built before or after January 1983?
Posted (edited)
1 hour ago, datzenmike said:
 Lug nuts are all tight?????
Yes they are
This made me laugh but i DID forget to check them initially
Edited by HomelessLemon
Posted (edited)
 A bad driveshaft yoke on an '85 Nissan 720 will typically cause intense driveline vibrations (especially at highway speeds), loud metal-on-metal clunking when shifting into gear, and jerking upon acceleration. It can also cause the transmission seal to wear out and leak transmission fluid.The specific signs and underlying issues caused by a failing yoke include:Heavy Vibrations: Worn splines or a damaged yoke prevent the driveshaft from centering properly. This causes an aggressive shudder or vibration that is often felt directly under the floorboards or seats and scales with vehicle speed.Clunking and Slop: A bad slip yoke will create noticeable free play in the drivetrain. You will hear a loud "clunk" when shifting between Park, Reverse, and Drive, or when taking your foot on and off the gas pedal.Transmission Fluid Leaks: If the yoke's barrel is worn or deeply grooved, it can damage the tail-shaft bushing and seal, causing transmission or transfer case fluid to leak out.Grinding/Squeaking: If the yoke runs dry of grease due to a bad seal or lack of lubrication, it will make scraping, whining, or squeaking noises.If left unaddressed, continued driving risks damaging the tailshaft, carrier bearing, and differential.Need help troubleshooting?If you'd like, let me know:Is your truck 2WD or 4WD?Are you feeling the vibration mostly when accelerating or coasting?Have you checked the carrier bearing (for two-piece driveshafts)?I can help you pinpoint whether you just need a new yoke or a full driveshaft repair on your Nissan 720.
33 minutes ago, Doomedwalker said:
Steady bearing maybe. Check the lug nuts too.
I don’t believe there is a carrier bearing from factory on my truck
Truck only vibrates under load and gets progressively worse from 1st to 5th gear. Rides smooth when i let my foot off the gas.
Posted (edited)
Just explaining what caused mine to vibrate and the same thing.But my yoke was bad.Could be something else on your's.Do like the transmission people did?Raise it in air.Start it and put in gear and drive in air and change all gears and see if the yoke is vibrating or where noise is coming from.Will need a lift like they use.
Here is my yoke with the part number in case you need one or anybody else needs one.It is rusted cause it has been in my shed for 9 years.Not good any way.
3-2189-5 +3 The identifier C2-3-2189-5 refers to a casted 1310 series transmission slip yoke commonly found in Nissan vehicles, such as the Nissan Xterra. It features a 24-spline count and a ~1.005" inside diameter.Key SpecificationsSeries: 1310Spline Count: 24Hub/ID: Approximately 0.995" to 1.005"Common Casting Number: C2-3-2189-5 (or C2-3-2189 5)Associated Part Numbers: 2-3-13461X, 2-3-13461XS (Spicer)Purchasing & VerificationBecause the same casting number can sometimes be used on structurally incompatible parts, it is highly recommended to verify your exact dimensions and spline count before ordering a replacement.Exact replacements and variations of this slip yoke can be sourced from specialized driveline suppliers:Northern Drivetrain: Carries the Spicer 2-3-13461X part.Driveshaft Parts: Offers the 2-3-13461XS for Nissan Xterra applications.Fort Wayne Clutch & Driveline: Provides the C2-3-2189-5 casting-matched unit (SKU# 2-3-13461X).If you need help confirming fitment, please let me know:What specific vehicle and year are you working on?Are you measuring the spline count and diameter to ensure a precise match?Would you like guidance on how to measure spline engagement properly?
The casting number C2-3-2189-5 identifies a genuine Dana Spicer 1310 series transmission slip yoke. It features 24 splines, a 1.376" hub diameter, and is primarily found on Nissan vehicles (such as the Frontier and Xterra).The direct replacement part number for this casting is Spicer 2-3-13461X (or 2-3-13461XS). You can purchase this replacement part or explore local availability through several verified distributors:Summit RacingNorthern DrivetrainDrivetrain AmericaO’Reilly Auto PartsKey SpecificationsSeries: 1310 (Outside lockup)Spline Count: 24 (includes blind/skip splines)Hub Diameter: 1.376"U-Joint Cap Size: 1.062"Center of U-joint to End: 6.045"Replacement & Tech TipsWhen installing, ensure that your slip yoke and spline maintain at least 2 inches of engagement inside the transmission tail shaft for safe, stable operation.Ensure the spline count matches your transmission output shaft exactly.You can seamlessly swap the old dust cover or boot from your C2-3-2189-5 yoke onto the new Spicer 2-3-13461X yoke.If you would like to proceed with your repair, could you let me know:What vehicle model and year is this for?Are you looking to order this part online or check same-day in-store availability near you?
I’m not experiencing any loud noises when shifting, no trouble getting into gears and no jerking on acceleration. It also doesn’t seem to be related to speed as the vibrations cease entirely when I let off the gas even above 80mph, could this still be the same issue?
Ok, if it's a 4x4 might not.
Carrier bearing only on the 2wd.
The rear most driveshaft is splined in the middle allowing it to compress under suspension travel. I think they are called a slip shaft. If splines worn or damaged the slip shaft will kink slightly under load and the balance will be lost.
Can't see this happening over night though.
Tires filled to maximum pressure?
Swap the front tires to the rear. Any change?
I would check the U bolts holding the axle to the leaf springs. Make sure the frame hasn't rotted away where the leaf springs meet the frame.
Use a 2x4 and try prying the transmission over to the side. Does the mount hold it in place? What about the transfer case can you move it by force?
Was chasing a similar vibration in a different vehicle - found bad u joints, shot trans mount and carrier bearing. Replaced them all, still same vibration. Ended up being the custom exhaust was mounted too tightly to the chassis, redid the hangers to give it slack and no more vibration. Also had a similar vibration when my motor mounts were shot and my oil pan was touching my cross member at certain load.
Transfer case is rock solid, I’ll recheck the transmission with something with more leverage tomorrow.
Tires are sitting at 35 but i regularly air them up/down depending on what kind of driving i’m doing. I briefly inspected the U bolts and leaf spring mounts and nothing immediately obvious stood out but I’ll definitely check those again tomorrow and move wheels around.
Not sure about the slip shaft, no amount of force I could exert with my hands would cause it to shift or play.
Everything points to driveline - something is kinking under load and relaxing on coast.  Speed related, but goes away or lessens without load, so not likely wheels or axles.
Update:
Swapped tires back to front, no change.
Aired down to 25 PSI, then up to 40, no change at either PSI.
Zero rot in the frame or leaf spring mounts, U bolts tight and in good shape
Transmission mount seems fine? I couldn’t get my hands on anything longer than a foot and a half but couldn’t pry it enough to get the transmission to move laterally more than maybe a few millimeters…
The symptoms seem to worsen after the truck’s been at operating temp for a few miles, which makes me think the issue may be localized within or near the transmission/driveline. I still can’t pinpoint it.
When I get the chance i’m gonna use a friend’s gopro mounted to the chassis while driving to see if i can visibly see anything problematic.
I do wish I had access to a 4-point lift as I believe that would make diagnosing this issue much easier.
Have a good look at the slip joint. Under load does it flex at all???..
U joints are hard to diagnose. Difficult to exert enough lateral pressure to show any movement, but this is no problem for a 100 hp engine. U joints should rotate freely but have zero side to side or up/down movement. Any, even small lateral movement, allows the driveshaft mass to move off center and vibrate. Driveshafts are balanced by welding weights onto them. Inspect your driveshafts for a clean spot where a balance weight may have come off.
spot_welded_weights_closeup__33568.15317
Look for driveshaft damage also...
images?q=tbn:ANd9GcSE4y9tSm4AC64ki95oAxa
Has the truck been raised or lowered at the back?????????????
  • 2 weeks later...
