Dats_Mandersun_408 Posted May 29 Report Share Posted May 29 Ive ordered a new clutch master cylinder and summit racing keeps delaying the order, there are others that I can get easier but they don't connect to the hard lines. Should I just replace the hardlines with braided lines or is it best to wait... Quote Link to comment
datzenmike Posted May 29 Report Share Posted May 29 How can they not connect to the hard line????? Quote Link to comment
Dats_Mandersun_408 Posted May 29 Author Report Share Posted May 29 the port is supposed to be on the side but the one at auto zone that says it fits has the port going vertical Quote Link to comment
datzenmike Posted May 29 Report Share Posted May 29 Likely they are confused and are trying to sell you a BRAKE master. They had vertical outlet. Tell them to try CLUTCH master. Check your old one, should be 5/8? Amazon has them in 5.8 fits almost all Datsuns and Nissans... https://www.amazon.com/Premium-Reservoir-Compatible-1977-1979-1970-1973/dp/B0DKBQLVD5 Quote Link to comment
Dats_Mandersun_408 Posted May 29 Author Report Share Posted May 29 oh nice ill give it a try, thank you! Quote Link to comment
banzai510(hainz) Posted May 29 Report Share Posted May 29 (edited) 17 hours ago, Dats_Mandersun_408 said: Should I just replace the hardlines with braided lines or is it best to wait... why do Datsun people make this hard/ Dont order from Summit Both are vertivle on the masters on a 521 and they SAE size. oh another thing is you might have to cut the threaded rod also as it make be too long as you install and hook up the rod to the pedal and push the mashet to the bulk head it will push on the rod thus applying pressure too soon. I put the nut on and cut the rod then unscrew the nut to clean the threads. https://www.partsgeek.com/catalog/1971/nissan/521_pickup/brake/brake_master_cylinder.html Edited May 29 by banzai510(hainz) Quote Link to comment
