lil Hustler 620 Posted March 14 Report Share Posted March 14 Hello, Banzi sent a video of top dead center. How does this look based on my photos? It's hard to see but the mark on the pully is on 5. Quote Link to comment
banzai510(hainz) Posted March 14 Report Share Posted March 14 drop the pump again and reinstall. use the red lines.make sure oil pump is full of oil when you put it in the final time..Use the RED line. notice top right of hole bottom is left of hole. Quote Link to comment
banzai510(hainz) Posted March 14 Report Share Posted March 14 (edited) I assume the crank notch on pulley is on the Zero mark on sawtooth timing plate. Most people paint it white yellow or a brite color looks like a reground cam. Hopefully you got the right lash pads ect set up. retainers .............. I assume you did the ink pen wipe check to make sure centered Edited March 14 by banzai510(hainz) 1 Quote Link to comment
lil Hustler 620 Posted March 14 Author Report Share Posted March 14 The mark is on 5. I will drop the oil pump and get it to your picture. Quote Link to comment
lil Hustler 620 Posted March 14 Author Report Share Posted March 14 Ok I think I might have it. As far as the notch on the pully pointing at 5, does that matter or does it have to be on zero? Quote Link to comment
datzenmike Posted March 14 Report Share Posted March 14 Each tooth is 180 Should be zero but for 50 it's fine. New alignment looks much better. 1 Quote Link to comment
banzai510(hainz) Posted March 16 Report Share Posted March 16 yes thats it. I like the new photo with the red line going thru cause depends where one stands looking at the spindal it can be a optical illusion sometimes, Quote Link to comment
Draker Posted March 19 Report Share Posted March 19 Pro tip, there is a dot on the spindle and a dot on the oil pump. You line them up, then install with the body of the pump in the correct orientation. That's the tricky part, but less ambiguous due to the shape. If you do this, you'll have good success getting the spindle in the correct spot the first time. Quote Link to comment
