Datsun 521 Trans gasket. HELP
  • Replies 8
I haven't watched it, but it should show you how to make your own if you don't want to use sealer by itself.
There are other ways to make the holes, but these are cheap and work well.  Put the gasket down on something fairly soft....like wood.  If you put the gasket on concrete, you'll ruin the edge quickly.
If you decide to use just sealant, make the nicest bead you can and let it dry for a few minutes before you install it.  I'm sure there's YT vids showing how to use just sealant.
  • Thanks 1
On smaller items I use a dollar store hole punch and scissors. Trace out on a sheet of gasket material or even a cereal box. My thermostat cover, water pump and oil pump are all from a Cheerio box.
