510 headlight relay question
Hi
What other model (vehicles )or after market headlight relay can be used instead of original part.ty
  • Replies 5
someone made a adapter using the standard black box relay.
you can most likely clean the one you have and make it work agaon by open the can up and clean the contacks.
most time the Lows dont work but both hi and low come on when high bean triggered is the standard proplem.
If all you have are high beams the parking lights are probably not working. You have to have working parking lights to power the hi/lo relay. No power, the relay stays in it at rest position of hi beams.
There is a few "how to" that i used to update my 510 headlight relays to modern. easy to get, relays.. But not sure what the link was .
I'm thinking the Dime quarterly , but mind is playing tricks on me.
You want one of these BLACK ones from an '80s 720/S110 200sx/S12/Maxima/ D-21. The internal circuit and coil is on the top. Cut the wires long.
