Led headlights
Hey people happy new year,quick question, how can I get the headlights swapped to ones like the hardbody,like what's needed ,or is there a video cause I see heaps for the hardbody,but none for my model specifically, ideas appreciated, im sick of getting led bulbs and have them scatter on the passengers side,abit frustrating indeed,so want to go the route of hardbody lights,ive never done this mod but have way more selection and designs available,also is there a specific name given to the light holders,or is it just buckets ,cheers people.
  • Replies 7
There are differences between NA and NZ vehicles. Post pictures of your front end. Not at all sure what you have.
Only shows the top half with the glass. Is what you have a WD21 or what we call the Pathfinder? Our D21 is the Hardbody. Even between Canada and the US the grills are different.
Don't the D21 and WD21 have the same large rectangular headlamps?
open your photo on a basic app and re-size it down. Assuming Windows, open the pic in basic photo app, right click on it and a drop down menu will open, resize image is about midway down.
Option2 is to take a photo from your phone and email it to yourself as a smaller file - iPhone gives 4 file sizes as choices
Na it's on my ph ,it's called a whd21 pathy  here ,same shape as the later d21 in the headlights,the model before mine was solely datsun here with the more square headlights, mine is the wider light with the notch in the lower corner, sorry bout this guy's, I forget about the model changes between countries, its the same as the 90s up headlights before the r50 shape which is similar to your Frontier design ,hoping it helps somewhat
W designates Z24 engine.
That would explain the light dispersion. The WD21 and the D21 lamps here are the same side to side. Are yours plastic?
No glass ,thats why i was looking to go with the swap to the orher type and go led,i know the grill needs to be changed,but u sure what else i need as never thought of going this direction ,but see plenty cruising about with with the mod,most wont talk to you about it,hence why im asking here ,i know a few have done this .
