Fitting a L20B engine in a 510
Datgramps510
I have tried a few different engine mounts and oil pan combinations. but I am having a hard time determining which are the correct motor mounts and which oil pan should be used to clear the crossmember.  What it the combination to get the engine to fit in the engine bay and not hit the cross member and allow the hood to close?
thanks for your help
  • Replies 2
stock metal mounts, you might need to slot them a bit to sit a little lower. There are taller rubber mounts, those didn't work for me. I had to use the OEM mounts which are a bit shorter. After that, it fits under the hood. For the pan, needs to be the stock L16 510 pan and pickup tube.
