Differential Palooza: Assessing old diffs
mtngoat
Posted (edited)
Good morning,
the Datsun parts re-org and cleanout is continuing apace at my place. We did our transmission assessment in the previous palooza...now it's diff time!
I haven't counted them all up yet because I haven't dug them all out yet, I can see several in the large heavy parts pile I haven't mined down to, yet. Others are loose.
I have at least three straight axle diff pumpkins and at least two IRS units, Z or 510 sedan as yet undetermined.
I never spent much time messing with the diffs on my various rigs, they just worked...or didn't. Didn't swap any ratios or anything. I'm not sure where all these came from! I did have a sedan and a Z for a while, so the IRS versions make sense...but where did all the others come from?
I do recall something about picking up a taller live axle version to bump up the gearing on the blue 2000, which was a 1600 conversion and I've never been happy with the low ratio in the rear given modern highway speeds. I want lower cruise RPMs, I'm not much on the point it and punch low gearing torque performance range. I did not install it, and I'm sure that's one of the loose ones.
Questions:
Can diffs sit for decades (out of the rain) and still be usable?
What do I look at/for to assess their condition?
How do I tell which fixed axle diffs are for what? Was there a standard size?
Same question on the IRS units.
Edited by mtngoat
  • Replies 4
Questions:
I assume the straight axle diffs are H-190.
Car H-190s have 23 spline side gears, trucks are 29 except the very early trucks like the 320, they were 21 tooth spline side gears. With care you can swap side gears to fit the axles you plan to use without affecting the set gear lash.
Gear ratios might help ID what they were in.
Roadster....... 3.889 (4.11 optional)
520............... 4.875
521............... 4.375
510 wagon... 3.90
Roadster, 510 wagons and 520/521 truck H-190 housings are aluminum. Light but not as strong as later steel ones.
620 2wd trucks 4.375 and 4.625. The '79 was 4.11.
720 2wd trucks range from 3.364, 3.545, 3.70, 3.889, 4.11, 4.375, 4.625
720 4x4 were 4.375 and 4.11. Sometime around '82 the companion flange was changed for a larger driveshaft. These won't fit the other H-190s and the flange can't be swapped.
D21 Hardbody and beyond 2wd 4 cylinder used the H-190.
Also ran...
The '82-'83 S110 200sx and the '84 S12 also used an H-190 differential.
IRS units...
The 510 used an R160 differential while the Z cars used R-180 and some later ZX used the R-200. This is the diameter of the ring gear. If they all look the same they are likely 510 R-160s. These came in 3.70 and 3.889 ratios. If 3.364 or 3.545 then you have a Z car or Maxima R-180. The 810 car had a 3.70 R-180 and a few ZX cars had 3.889 R-180s.
On 11/26/2025 at 12:01 PM, mtngoat said:
Questions:
diff can sit indefinitely if they are sealed and out of the elements.
spin it  - if its smooth and quiet, thats a really good start
post pics, that helps
  • 8 months later...
With Red 2000 now out of the shed and up on blocks, we pulled the entire axle assy out for inspection. Brake line was roached, so we cut it. No diff in it, it's covered in road grime and what may be axle oil, i'll have to investigate around the brake parts for the tell tale seepage marks from a leaky seal.
I think I snagged it's diff for what is now our donor car, so we put that fellow up on blocks as well (pine rounds) for simpler parts stripping, then pulled the entire assy as well. They're now side by side outside the shop waiting for cherry picking all the best of the two and putting it onto one axle, then it will go back in Red.
Assuming it's not rusty in there, I guess clean gears and only a touch of backlash is a good sign?
