Clunking while driving
BillM
  • Replies 14
Most likely:
Loose exhaust pipe, broken clamp/hanger. Muffler bumping body.
Going over bumps or turns?
Spare and jack secure? Broken or loose shock? Broken coil spring? loose lug nuts? Hatch not adjusted properly.
5 hours ago, BillM said:
Occasional clunking while driving. Coming from just behind cab. I've changed out the driveshaft and greased the rear spring bushings. Sounds like a 12" steel bar banging around, can't find anything loose underneath.
Any ideas?
Bill
Won't have been the drive shaft. U joints can make noise, usually a squealing sound and or vibration, sometimes a clunk when engaging clutch on take offs but if drive shaft replaced I assume the U joints would be new also.
Grab the exhaust pipe and really shake it HARD. Does it or the muffler hit anything??? Now do the same to the shocks. Don't pull the car down on top of yourself. Climb up on the bumper and bounce the rear of the car. Anything?
Well-I pulled the bed off of it today and drove around a bit. Totally quiet, no creaking. Put the bed back on and creaking started again. I'm guessing that it is the pads creaking. I think that I will make up some new pads and see if I can make it quiet.
if i recall correctly, some of the body fasteners just use a shim between frame and bed. Those just tighten. But there are a couple that have round poly spacers, and those might have disintegrated, or more likely compressed down too far
Well, it seems to be fixed!
Greased all of the fittings on the front suspension and magically all of the squeeking and clunking stopped. I'm guessing that the truck hadn't been greased for about 30 years from the condition of the plugs hiding the greasing holes but it now drives as nice and quietly as a new truck.
Billm
Billm
Better check the ball joints.
16 hours ago, ElliotV said:
wouldn't hurt to take a close look at the ball joints for sure and check for tears in the boots, they really aren't hard to replace and are cheap enough
A friend's 720 was making that noise. It went through frame, couldn't figger source. Was dang hard to get on the tow dolly with ball joint failed and wheel flopping around. Fortunately he had just made a doubleback right turn and was going slow.
Edited by DwayneOxford
