SKYBLEW Posted August 17, 2025 Report Posted August 17, 2025 I found these NOS shocks yesterday, labeled 48531-35820. Free lenght is 21.0", the valving, feels good, pretty heavy, I measured my old shocks at 22" FL, plenty of compression and rebound, gas charge still working, I calculated the working height to be about 18.0". On-line research shows a close part number, not exact, belongs to the Corolla family, probably the EA86. I'm sure their fine to work with my genuine BRE rear springs, just wondering if the community has seen these shocks before? Secondly I also picked up 2 48521-35880 shocks, waaay too short for our rear application, free lenght of 13.5" which makes a working lenght probably 9.0" Lastly, how can I share images off my phone? I only see insert from URL available. Quote
ggzilla Posted August 17, 2025 Report Posted August 17, 2025 (edited) 4 hours ago, SKYBLEW said: how can I share images off my phone? I only see insert from URL available You can post the image to a photo sharing web site, like imgur.com. Then add the photo URL to the reply imgur.com does not require an account, it will ask you to create one, but ignore that and upload the photo without creating an account After you have made 26(?) posts then Ratsun allows direct photo uploads Edited August 17, 2025 by ggzilla Quote
ggzilla Posted August 18, 2025 Report Posted August 18, 2025 (edited) Corolla has direct-acting shocks. The 510 has leveraged shocks, about 2:1 so presumably the shock valving will be much heavier compared to Corolla. With BRE springs, you might want even heavier valving again That being said, they probably will be much better than worn-out shocks By "free length" do you mean compressed length or extended length? Edited August 18, 2025 by ggzilla Quote
ggzilla Posted August 18, 2025 Report Posted August 18, 2025 6 hours ago, SKYBLEW said: I found these NOS shocks yesterday, labeled 48531-35820 ... just wondering if the community has seen these shocks before? I hadn't heard about those. Tokico says they are 1992 Toyota 4Runner 4x4 rear shocks Toyota USA doesn't list that part number. But here are specs from Monroe 37033 interchange $26 at RockAuto: * Stroke travel: 7.625 inch * Min. length 13.250 inch * Max. length 20.875 inch * Mount type lower: loop bushing 3/4" I.D. x 1-9/16" * Mount type upper: stem mount 2-3/8" x 3/8x16 thread Gabriel G63548 * Min. length 13.08 inch * Max. length 21.11 inch Monroe 59325 $13 * Min. length 12.875 inch * Max. length 20.875 inch Here are the 510 sedan rear shock specifications * Stroke 206mm (8.110 inch) * Max. length 568mm (22.362 inch) * Rebound 45kg (66kg hard suspension) * Compression 28kg (42kg hard suspension) reference: Nissan Service Manual Model 510 Series 1973 page RA-11 Min. length is estimated at 362mm (14.252 inch) Quote
