somebody save this 521
banzai510(hainz)
  • Replies 26
nice
521a.thumb.jpg.063e8c656904810c8c0d53c343daf9c5.jpg\
Good Running (Rust Free) 1971 Datsun 521(1600cc) Pickup Truck-For Sal - $1,500 (Stevens Lake)
I have 1971 Datsun PL 521 Pickup truck .....For Sale......It runs good......1600 engine......4 speed manual transmission...
This truck has no rust .......because it has been parked inside a garage since 1985..!!
It needs a little TLC......and it's ready to go have some fun.......(with you in it!)
For more info.....please call Jon.......anyday from 8 am to 9 pm.....or you text me anytime....
(NO E-MAILS AT THIS TIME....THANKS...JON.)
THIS TRUCK IS WORTH AT LEAST TWICE WHAT I'M ASKING FOR IT.....I KNOW THAT.....IT'S ALL ABOUT FINDING
A GOOD HOME FOR THIS TRUCK.....WHICH IS AN AWESOME 'SURVIVOR'......IF YOU WANT A TRUCK LIKE THIS
....I CAN'T IMAGINE FINDING A BETTER DEAL THAN THIS.....I EXPECT THE FIRST PERSON TO LOOK AT IT...
.....WILL BUY IT......LOOK UNDERNEATH IT......AND AT THE ROCKERS ETC....AND IT LOOKS EVEN BETTER...
That pickup reminds me of the one Tana used to have. Oh wait, that was a Datsun 410 well it was the same color at least
My '71 was red and just like that. Had it eight brutal years with zero maintenance, just fix things when they failed. One tough truck.
On 8/16/2025 at 1:31 PM, ggzilla said:
nice
On 8/17/2025 at 4:02 AM, NC85ST said:
Man, I wish that was on my side of the world! I’d buy it in a heartbeat!
i believe  this sold already no longer posted on craigslist
  • 4 months later...
nice
didnt sell so i bought it
If you have never done this swap before, stick to rebuilding it or finding another L series engine. I swapped to an L20B in my '71.
Posted (edited)
On 1/20/2026 at 12:29 PM, mike808hawaii said:
engine dont run very good
if its running then its something simple and ez to fix under 500 bucks I bet.
tight valve?
lash pad fell off
spark plugs
dist cap
distributor maybe worn. points not gapped or a 1.99 condensor bad or loose wire.
If you cant check these then you cant work a KA eleltrical and refit a whole exhaist ect.... exhaust shops are not cheap anymore
Photos of the engine bay and dist elelctrical
Edited by banzai510(hainz)
On 1/20/2026 at 5:35 PM, banzai510(hainz) said:
If u cant get a Lmotor going u more than likely not get a injected motor wire swap going.
yeah was looking into a kswap or a ka24e
tight valve?
lash pad fell off
spark plugs
dist cap
trucks been sitting over 40 years in a barn or garage i was told  so im pretty sure the rings are crusty  as  sounds like wall scrapping and it smokes kinda bad even after  adding treatment to the oil  she seems to squeel a bit   top half seems ok  maybe send engine to repair i dont know yet  coz original miles on it is like 55,000  as i have the last reg that was 1985 and a log owner kept on mileage
check the belts? have you replaced it?
alternator spins with hand? mayby bearings going out getting tight.?
squeel maybe timing chain. Simple front cover pull and timing chain install.
Cylinders won't rust if hood closed, kept inside and air filter left on.
Run it for a few weeks so the belt polishes the rusty pulleys then skip to the chase and put a new belt on. If not fixed it's best to have a new belt on it any way. If not belt or pulleys then most likely the alternator bearing.
Pick a spot between alternator and water pump and push down on belt with thumb. If properly tensioned, it should deflect no more than a belt width.
Does your 521 have a belt driven air pump???? Remove the belt.
