1979 H190 3.88 make that 4.875 ring & pinion
Danz
15 minutes ago, datzenmike said:
wayno, is there an issue with bolt sizes? SAE ring gear holes being fitted to later metric housing. You would have to use the metric fasteners but do they fi the SAE holes? or do they need to be drilled out?
1/2" SAE bolt is 12.7mm but the metric bolt is likely 13mm
What I am saying is to put the 620 side gears(29 splines) into the 320 gear set with 4.8 gears.
  • Replies 26
