Datsun 510 Grille
ggzilla
NOTE: There are various old topics about this on Ratsun, but most of the pics have expired. Please add photos and comments as you see fit
Datsun Model Series 510 (sold outside North America as the "Bluebird 510" or 1300/1400/1600/1800 depending on the engine size). PL510 was sold in Europe and North America and designates LHD with P engine (1600 engine). H510 is the H engine version (1800)
* All trim models use the same style grille, with the emblem differing on base, Deluxe, GL or SSS cars
* SSS sometimes had the grille painted differently (black or with white stripe)
* 2-door Coupe grille differed from 2-dr sedan grill
1967-1968 stainless steel grille with center horizontal badge. This one has the 'D' emblem used on Deluxe models
1969 Sedan/Van/Wagon has a doubled center bar and vertical center badge
160220888795d565ef66e7dA-16.jpg?fit=940,
1969-1971 Coupe 1600. This one has an SSS badge and "white-stripe" center rib
1970-1971 SSS grill (also used 1970-1973 North America)
1972_datsun_510_1602598153fb1b266pic-05.
1970-1971 JDM Deluxe grille
1972 JDM grill metal with plastic headlight buckets. The "supersonic" emblem bolted on used on Deluxe cars
0400271A30191225W00101.jpg.479be26e3138b
510 OPTION PARTS Fog Lamp grille
Edited by ggzilla
update links
  • Replies 11
1967-1968 Grille (1968 model year started in 1967 in both Japan and North America)
* dished headlight bezels
* horizontal center emblem
62300-21000 GRILLE-radiator Standard
62300-21600 GRILLE-radiator DELUXE Sedan & all Wagon
62400-21000 FINISHER-head lamp RH
62401-21000 FINISHER-head lamp LH
1968 9-slat stainless steel grille with center horizontal badge. The grille center is forward of the headlights, matching the lines of the hood
photobucket-53865-1353613131574.jpg?t=13
The headlight bezel finishers come forward where they meet the grille center
1968 grill with some bars painted black and a JDM red/black/blue 'D' EMBLEM
1 GRILLE
6, 7 HEAD LAMP FINISHERS
14, 17 MOULDING
10 HOOD TOP MOULDING
17 FRONT CENTER MOULDING
1968 Grille Badges
62800-21000 EMBLEM-radiator grille center 'D' (JDM)
62800-21300 EMBLEM-radiator grille center 'DATSUN' (USA)
JDM multi-color red/black/blue with "D"
USA red with "DATSUN"
horizontal badges
Type 213 emblem 'DATSUN'. the paint is often faded away to nothing
hand-painted to restore the red
1969 10-slat stainless grille with flat headlight bezels
* flat headlight bezels
* vertical center emblem
* Stainless trim surrounds same as 1968
62300-A0600 GRILLE-radiator Standard Sedan & Van
62300-A0800 GRILLE-radiator DELUXE Sedan & all Wagon
62400-A0600 FINISHER-head lamp RH
62401-A0600 FINISHER-head lamp LH
* Coupe differs. See next post
1969 grille has 2 thicker center bars
1969 Coupe (JDM 2-door fastback) uses same grille as other 1969s but has a "white stripe" in between the two center bars. Coupe debut 1968.10
See next post
Customized: badge delete and most of the slats painted black
Grille with R and L moldings
bezels wrap around headlights and do not bulge forward to meet the grill like the '68s
1969 grille badge
62800-A0600 EMBLEM-radiator grille center Sedan 'D' vertical  ALL
height about 11 cm
Edited by ggzilla
1969-1971 Coupe looks similar to the other 1969s but has a white stripe in between the two center bars
62310-A5201 GRILLE-radiator Coupe 1600
62310-A9400 GRILLE-radiator Coupe 1800
62400-A9400 FINISHER-head lamp RH
62401-A9400 FINISHER-head lamp LH
* Stainless surround moldings differ
Coupe grille (with SSS 1600 badge)
5EC40B60-4280-4A66-A510-DE008800A4AF.thu
"White stripe" Coupe grill (with SSS 1600 badge)
1969-1971 Coupe Badges
62800-N0510 MARK-radiator grille "Coupe"
62800-N0401 MARK-radiator grille "SSS" (1600)
62800-A8700 MARK-radiator grille "1800 SSS"
62800-A5211 badge
1800 SSS badge is approximately 14cm wide
Edited by ggzilla
1970-1971 sedan/van/wagon grille situation gets complicated
* Type A49 Standard
* Type A90 Deluxe/GL
* Type A87 SSS. Also used for all USA 1970-1973
SSS and USA has shiny center bar
JDM Standard has black center bar (also used by SPORTS model)
JDM Deluxe
Customized 1970 grille with only top & bottom slats shiny. The rest has been painted black
1970-1971 Badges are to the left side of the grille and have a red/white/blue flag (Datsun colors)
62800-A4611 MARK-radiator grille side "BLUEBIRD"
62800-A8900 MARK-radiator grille side "GL"
62800-N0200 MARK-radiator grille side "1600"
62800-A5405 MARK-radiator grille side "SPORT"
62800-A5411 MARK-radiator grille side "DATSUN" (used 1970-1973 in USA market)
1600
1600
1600 emblem is supersized
SPORTS bolt spacing differsSPORTS_back.thumb.jpg.ac7ec3a1697ff49fde95d5bbeb7e8f64.jpg
SPORTS
Edited by ggzilla
1972 JDM metal grille with plastic headlight surrounds
* 4-door sedan
* 2-door sedan
* 2-door coupe: none made for 1972. Instead see 1972 610 Bluebird-U Hardtop
Do these three grilles differ in color finish? In car photos they all look the same, although some have gray surrounds, some black
62310-N2000 GRILLE ASS'Y-radiator SSS
62310-N2100 GRILLE ASS'Y-radiator Standard
62310-N1600 GRILLE ASS'Y-radiator Deluxe
* Stainless surround moldings are same as 1970 except RH/LH differ after 1972.02
1972 Deluxe grille with Deluxe supersonic badge
Deluxe
1972 SSS grille with OPTION SSS badge
i-img1200x900-1557676259puxfyp375545.thu
1972 GL grille
2049463145_SSGrill.thumb.jpg.e8f8f1115b0
4-piece design: Grille center, top bar, LH and RH headlight buckets all bolted together with brackets
62800-N2025 MARK KIT "SSS"
62800-N1725 MARK KIT "GL" (N1700 Ornament)
62800-N1625 ORNAMENT A Deluxe
62800-N2125 ORNAMENT B Standard
1972 "GL" 62800-N1700
510 OPTION PARTS Fog Lamp Grille, nicknamed by some the "Safari" grille for some reason
It has clear lens; lamp body reflector is gold
with bullet connectors for the lamp wires
Make your own: datsunfreak: DIY safari grill
62300-26505 GRILLE Fog Lamp
62400-26505 FINISHER-head lamp RH
62401-26505 FINISHER-head lamp LH
Type 26510 FOG LAMP (grille mount) Ichikoh Deluxe iodine halogen
* For parts details, see: Datsun 1200 Club: 510 Fog Lights
62800-26506 MARK-radiator grille "SSS" OPTIONAL PART KP510TK
62800-26500 MARK-radiator grille "D" with eight supersonic icons
Not an SSS factory part, but sold via the 510 OPTION PARTS catalog. The SSS badge was optional too
This type 265 "D" emblem matches the overall style of 1968 grill badges
four little supersonic icons on either side of the 'D'
SSS Restorers has much better photos. I can't find a list of details/differences on their web site
My list came from Datsun USA and Datsun Japan parts catalogs, and trying to match up photos. But part of that is interpretation as the parts catalogs don't have photos, only drawings. The photos here came from previous Ratsun posts and from eBay and Yahoo Auctions
  • 8 months later...
This is a 1969 JDM 'Base Model' 510 Coupe grille badge.
