1984 4x4 King Cab 720 parking brake cable routing
  • Replies 3
Since you'll have the parking brake in the off position to facilitate replacement, block both front tires with a 2x4 before and after the tires. Then you can safely jack up the rear. With a 4x4 you don't even need to jack it up, if you don't mind sliding under the truck on a large piece of cardboard
1 hour ago, dustinsandwich said:
anything I should know of or be prepared for before I jack up the truck?
8 hours ago, ggzilla said:
Take multiple photos of the old parking brake wires and connections before you start disassembly of the old parts
Unfortunately the previous owner already removed them.
I was planning on jacking it up and using stands so I can do the tranny oil and address a few cut wires for the back up lights while I'm down there. I'm very careful about safely lifting cars, I'm not getting a crushed ribcage for an oil change. Thanks for the advice!
