Outlet00 Posted February 15, 2025 Report Posted February 15, 2025 hey guys today I'm stumped because I've been trying to figure out how to install some things I'm missing I bought this truck used very used. My whole dashboard doesn't work and I'm wondering which other 720s I can switch parts with because there are some near me but not a whole lot. I don't even know where to go to looking for parts. I also need all of my transmission gasket and seals and oil pan gaskets replaced for the five-speed I think 2wd. if I can get some information on what dashes are interchangeable at least and where I could probably find my gaskets and seals that would be helpful My ignition is non-existent I used a remote starter switch because the other guy ripped it out so if I can get help figuring out how to connect a new key in switch that would be nice I own a 79 620 also but I need to clean out the engine since it was sitting for 20 years and everything solidified Quote
wayno Posted February 19, 2025 Report Posted February 19, 2025 You will need a Diesel instrument cluster, nothing else will plug in to the wiring harness. As for the ignition, this depends on if you have the diesel components in the engine bay, if that stuff is missing you will need a choke cable and button/relay to warm up the glow plugs. Quote
