Distributor Wires?
Fostin510
So I have a distributor from a 78 510 that I want to use in my 69 510. I has a red and a green wire that come from the same location inside the distributor. Which is which?
Thanks
  • Replies 16
Posted (edited)
There is more to it than that.
the 78 uses a black box that was inside the vehicle. If you dont have that then one has to use a GM module to hook up the Red and Green wire to and then the hook up to Power, and use a Later model Coil.
Best is to show what you have now or is it stock dist with points or what.
also make sure the distributor came with the mount and timing plate otherwise might not match up with a stock L16 dist or who knows what you have 50years later on this
Edited by banzai510(hainz)
I'm running it with an L20b, No points, the inside of the distributor has a lazy V shaped piece with the two wires coming out of it. As for the GM module, I've seen a few different types, which would be best? I looked at Rock Auto to identify which distributor I had. I've been doing a bit of research but can't seem to identify the red and green wires. Do I need a coil designed for electronic ignition?
Outstanding!
I'm trying to get it running outside the car before I install it.
While I have you, your opinion. The original L16 ran a 35amp alternator with a pigtail connection. That one is toast and it's replacement is over $100. Time to upgrade???
Posted (edited)
photos be best to see what you got for ignition.
. If you dont have points then why you want to use this distributor?  L16/18/20 is virtually the same when it comes to the ignition. The ignition is with the car untill somebody changes it.
Yes one would best put the newer type low ohm coil in there but as you just said you dont have points. But maybe you have a pertronix set up or a Unilite. best to see what you have. I also have a few 78 dist but I dont use them. I got as spares untill maybe I have to use them.
as for the GM moduel alot are cheap junk so I dont know what people use but the AC delco one might be 40$ and up, I myself run the Pertronix conversion. I have good luck with them.
as for the 35amper alt I know what your saying. The L16 uses the smaller bolt holes in the ears/alternator mount. So if there is a bigger amp alt you have to amke sure you order for a 510 a 50amp option i think it is.  The later 610/710 had the 50amper but the holes are bigger like a 3/6 size hole. Be hones most alt now dont last long. I never got 3 years out of a starter on alt on a daily driver.. i know dont drive them much so Havent worked on them all to often now.
that special pigtail (Alternator)maybe your car was made in late 68 for the  69 year. The early 521 and 510 had these I rarely see them anymore. Photo will help. I found this
https://www.ebay.com/itm/387850462408?fits=Model%3A510|Make%3ADatsun&_skw=datsun+510+alternator+pigtail&itmmeta=01JKBS1N70VAMCRN7NZPN9SW0J&hash=item5a4db064c8:g:3agAAOSwe~Vm00gs&itmprp=enc%3AAQAJAAAA4HoV3kP08IDx%2BKZ9MfhVJKnaodn5RZcuMYfPkDBPpBmUHUdzaEFOyRbIZeIl%2FTB%2BRqbEriLSB9voyGcdjZnh8iFN%2Fh8JHlIhyLdm3B152rgjQzdGGZ0QgFbKCrPqzjWiQ1rXWuyUzpQElK3BenieloGklVxc03EVr11TdzkMA0Ge5XLjbUvWlL09Nh1oLGwr1e34ykadAWkPFQR03qkh1rKklO%2BVKQqYaKZEA7EePDfP0TMKlRl3OJrWggnb0kyYrhDfIGdshCZizkA8L6bDHASC2XbVoom1mROo9nioJNGf|tkp%3ABk9SR7DUhvmaZQ
Probably looks like this...
If from a '78 you will have what's known as a remote igniter distributor. Remote meaning the transistor module is mounted somewhere under the dash in the cab and when people harvest this EI distributor they fail to grab and keep it with the distributor. That's fine you can simply use an HEI module from a late '70s GM product.
The Red and Green wires are the trigger pulse causes by rotor magnets passing by the coil. This pulse is used by the igniter (or HEI module) to fire the coil. Here's a wiring diagram (ignore the coil resistance rating) use the EI coil from any '78 and up Datsun to take advantage of the much higher output. You can use the 510 coil, but if you do, keep the ballast resistor functional.
There is a remote chance that it will fail to work, just swap the Red and Green wires around. Something about the trigger pulse being negative rather than positive direction. No worries you can't harm anything.
... While I have you, your opinion. The original L16 ran a 35amp alternator with a pigtail connection. That one is toast and it's replacement is over $100. Time to upgrade???
Yes very low 35 amp. output on the early 510 alternator. Any 610/710 B-210 after '74 alternator but before '78 will drop in and have 50 amp output. If so inclined you can convert your 510 electrical system to run a '78 and later alternator that is internally regulated. This gets rid of the mechanical regulator on the inner fender and uses a solid state (basically it means no moving parts to wear out) transistorized regulator fitted into the alternator case
It's a simple thing to convert from external regulator to later '78 and up internally regulated alternators in the 1600. Cut the plug off the external regulator leaving the wires long. Join the White/Black stripe wire to the White/Red stripe wire. Join the solid White to the solid Yellow wire. Solder and use heat shrink tubing to seal. Remove the unused wires so they won't cause any problems. Now just plug this into the engine harness and you can remove the old external regulator. 1978 was the year all Datsun/Nissan vehicles switched to internally regulated alternators, or it was, in North America.
859462763_wiring510elecchokeregulatorbyp
Dont even have to cut the wires if the VR is good.Not to waist it. I cut the and save them from bad Volt Regs.
be careful I seen where the wire colors are correct but were off on wrong pin if you go this route. use the engine side harness as ref for wire colors
Just make 2 jumpers with male blade connectors amd put them in the harness
So I looked at the ad on Ebay and the part was sold out. Be willing to bet, there's someone out there with electrical brains that could start building those connections. I'm sure someone might buy them... I suffer from electrical dyslexia. I'm bound to fry wires or set off a small explosion.
Webers, yes at some point. The hood? That's all you. Don't want to be a copy cat, although it is pretty cool.
  • 1 year later...
So, if I may hijack for a second...
What if I have a 78 with an intact remote igniter box but it's condition (along with the entire ignition system's health) is in question? Would I be better off to swap it out for a GM setup now rather than sourcing 'hopefully good' OE parts?  And if so, what about using an old MSD box? Super old-school setup that runs a piggyback rev limiter. Has all the fancy sparks, they say.
I'm having a no-spark issue right now in the 620 that's sat in the woods for almost twenty years.
To actually test for spark pull the center wire to the distributor cap off and place a spark plug in the end. Hold the spark plug against a grounded surface such as the exhaust manifold while someone tries to start the engine. If there is spark you will see it. If no spark things to check...
1/  Check that there is 12v on the coil positive terminal with ignition ON and that the distributor is securely grounded.
2/  With ignition ON hold a grounded wire briefly to the coil negative terminal and release it. There should be spark on the coil wire going to the distributor when the wire ground is removed if coil is good. No spark means the coil is faulty.
3/ If there is spark at the coil wire, test for spark on one of the spark plug wires by turning the engine with the starter. If there is spark from the coil but none at the plug wire there is something wrong with the distributor cap or the rotor.
4/ If there is no spark from the coil it's likely the remote igniter box is at fault.
Only because the remote ignitor box and wiring is long (all the way to beside the glove box and back) and would be a nightmare to troubleshoot, I would wire up an HEI module.
Just ignore the 1.6 ohm coil rating. Use the remote ignitor coil on the '78. Be sure the distributor and the HEI module are securely grounded.
just a heads-up with regard to the GM HEI modules: they degrade and cause ignition timing and minor misfire issues. They typically won't leave you stranded on the side of the road, but they will have you chasing your tail with a minor misfire. Make sure the module is grounded. Orig install had it bolted to the base of the HEI distributor, grounded and insulated with dielectric grease - there is a metal grommet on top where the bolt goes through, its connected to the bottom of the module providing the ground path.... if you are running this module and are experiencing a minor misfire start there...
I have ran a remote style distributor off of both the GM HEI module and an MSD box. Both worked fine. The MSD box does make noise, so if you go that route, I'd mount it in the engine bay. I have always been told the match box distributor is a better option over the remote mount, due to the fact the remote mount has one pickup point for spark activation and the match box distributor has 4.
