Crashtd420 Posted January 25 Report Share Posted January 25 So I know this about my wife's vw bus but she is running a weber 32/36 which is in many datsuns.... While working on some stuff I noticed a missing plug.... I found a stock picture and confirmed my suspicions.... My question is this, is there an idle jet behind it? Because I'm wondering if it's there or not... This is a picture of the idle jet, and I don't think I could install one plus the plug so I think the jet is in there... Are those a pressed in jet, I don't even know how it would come out.... Any insight will help, as of now I'm going to order the plug because I know I atleast need that.... Quote Link to comment
Crashtd420 Posted January 25 Author Report Share Posted January 25 Well while looking for the plug i understand how the jet is held and I have definitely lost that too... Saw this picture... Now to figure out what jet i need... Quote Link to comment
Crashtd420 Posted January 25 Author Report Share Posted January 25 So it looks like I'll just have to get a couple... I can get a 4 pack so I'm planning on just, 40,50,60,70.... I have a small drill set so I can drill out if necessary to get a half size.... Maybe it was a good thing since her throttle cable and linkage wasn't correct... so she was never actually opening the secondary butterfly.... That has been corrected.... I'm still not sure how the secondary idle works or when.... Quote Link to comment
banzai510(hainz) Posted January 25 Report Share Posted January 25 figured it would NOT idle if that was missing. ??? or maybe get massive amouts of fuel and leak out if no brass screw cover Quote Link to comment
Crashtd420 Posted January 25 Author Report Share Posted January 25 1 minute ago, banzai510(hainz) said: figured it would NOT idle if that was missing. ??? or maybe get massive amouts of fuel and leak out if no brass screw cover I thought that, that's why I was wondering the function also... It's the secondary, luckily it didn't leak fuel since I don't believe it can draw the fuel up, if anything it was a vacuum leak.... Quote Link to comment
Stoffregen Motorsports Posted January 26 Report Share Posted January 26 Yeah, that's a pilot jet. Can't run without that. If the one that's missing is larger than the one on the other side of the carb, it is a fuel cut solenoid. Quote Link to comment
Crashtd420 Posted January 26 Author Report Share Posted January 26 32 minutes ago, Stoffregen Motorsports said: Yeah, that's a pilot jet. Can't run without that. If the one that's missing is larger than the one on the other side of the carb, it is a fuel cut solenoid. Well hopefully not a fuel cut, I think it's just a jet from diagrams I have found ... What's crazy is it was running and I have no idea how long it's been missing... Quote Link to comment
Stoffregen Motorsports Posted January 27 Report Share Posted January 27 Actually, the fuel cut solenoid is a worthy upgrade. Quote Link to comment
Crashtd420 Posted January 27 Author Report Share Posted January 27 1 hour ago, Stoffregen Motorsports said: Actually, the fuel cut solenoid is a worthy upgrade. I agree but she has never had a dieseling issue on shut down so I might just leave it alone.... I do have secondary jet and holder on the way.... 1 Quote Link to comment
