Socalman Posted December 28, 2024 Report Share Posted December 28, 2024 I am missing this piece on my steering column, looking for a replacement or ideas on what others are/have used…if anyone has a source, I am thinking of using a thrust washer or bearing…I believe it’s called an ASSY-BUSH COLUMN JACKET 48054-20500. Was unable to locate a source… 1 Quote Link to comment
datzenmike Posted December 28, 2024 Report Share Posted December 28, 2024 Called a collar though I would call it a collet just like the keepers on a valve stem. There are two held in place with a wire that wraps around that small groove. The Collar is 40418-30800 the spring is 40419-30800 although a cotton thread will do to hold in place till the wheel is on. These two parts are on every Datsun from the Roadster/520/521/510 through the mid '80s. So lots out there if you ask. It's tapered and fits a taper in the steering wheel so NO washer and NO bearing or the wheel won't attach properly. Your 48054-20500 is actually a bushing down in the steering column tube. Quote Link to comment
Socalman Posted December 29, 2024 Author Report Share Posted December 29, 2024 3 hours ago, datzenmike said: Called a collar though I would call it a collet just like the keepers on a valve stem. There are two held in place with a wire that wraps around that small groove. The Collar is 40418-30800 the spring is 40419-30800 although a cotton thread will do to hold in place till the wheel is on. These two parts are on every Datsun from the Roadster/520/521/510 through the mid '80s. So lots out there if you ask. It's tapered and fits a taper in the steering wheel so NO washer and NO bearing or the wheel won't attach properly. Your 48054-20500 is actually a bushing down in the steering column tube. Thank you! Quote Link to comment
datzenmike Posted December 29, 2024 Report Share Posted December 29, 2024 Try a want ad here.... https://ratsun.net/classifieds/category/9-datsun-parts/ Quote Link to comment
mklotz70 Posted December 29, 2024 Report Share Posted December 29, 2024 LOL....that's a pic in my shop. I just looked up a vid of mine.....at the 3min mark, you can see that the 510 column has the same tapered collar. I'm pretty sure all the Z cars and other models will have the same collar. The spline and it's diameter is the same on all of them. Quote Link to comment
Socalman Posted December 29, 2024 Author Report Share Posted December 29, 2024 8 hours ago, mklotz70 said: LOL....that's a pic in my shop. I just looked up a vid of mine.....at the 3min mark, you can see that the 510 column has the same tapered collar. I'm pretty sure all the Z cars and other models will have the same collar. The spline and it's diameter is the same on all of them. Haha, it was you but it was photos…here 1 Quote Link to comment
Socalman Posted December 29, 2024 Author Report Share Posted December 29, 2024 I was trying to figure out what I was missing and came across it.. 1 Quote Link to comment
mklotz70 Posted December 29, 2024 Report Share Posted December 29, 2024 I still plan on finishing this write up and videos......someday. lol Quote Link to comment
Socalman Posted January 6, 2025 Author Report Share Posted January 6, 2025 just an FYI, while waiting on the oem part from Japan, I just want to say 3/4" thrust washers work great, if parts are unavailable or you are in a pinch, I will report back with any issues if they arise...I feel like I have power steering now. LOL 1 Quote Link to comment
Socalman Posted January 22, 2025 Author Report Share Posted January 22, 2025 This is so stupid is almost funny, part number 48418M steering wheel collar, I ordered 1, you would think its a collar, right? well they sent 1 piece, which is half the collar. you need to order 2 to complete the collar, apparently.... LOL Quote Link to comment
datzenmike Posted January 22, 2025 Report Share Posted January 22, 2025 Shown above is for a Stanza with a part number for each half. Others show one part number covering both. Either way they all say the same price, about $1.50. Quote Link to comment
Rotarded Posted January 27, 2025 Report Share Posted January 27, 2025 On 1/22/2025 at 1:28 PM, Socalman said: This is so stupid is almost funny, part number 48418M steering wheel collar, I ordered 1, you would think its a collar, right? well they sent 1 piece, which is half the collar. you need to order 2 to complete the collar, apparently.... LOL I no longer need mine man let me know and I can bring it with me to Colton, I got the brakes off you. My new setup will not use that spacer so if you need. Quote Link to comment
Socalman Posted January 27, 2025 Author Report Share Posted January 27, 2025 40 minutes ago, Rotarded said: I no longer need mine man let me know and I can bring it with me to Colton, I got the brakes off you. My new setup will not use that spacer so if you need. I appreciate that, that's really cool of you, I have a couple coming, if for some reason they don't fit, I will text you...Thanks! 1 Quote Link to comment
