85"720 Posted November 28, 2024 Report Share Posted November 28, 2024 Does anyone know where I can buy a vacuum advance pot for my stock distributor. It's a 1985 720 2.4 rwd california model Quote Link to comment
datzenmike Posted November 28, 2024 Report Share Posted November 28, 2024 Best would be from another truck. The part number is 22301-80W00 though I doubt the Nissan dealer may have one, maybe you can use this number to cross reference it to another supplier. I doubt California emissions will check this so one from another distributor will work but it's advance curve will be different. Quote Link to comment
Thomas Perkins Posted November 28, 2024 Report Share Posted November 28, 2024 Here is the part number.22301-80W20.I check the one Mike listed and it says it does not fit a 85. Quote Link to comment
Thomas Perkins Posted November 28, 2024 Report Share Posted November 28, 2024 (edited) This part does not fit 1985 Nissan 720 Pickup King Cab; 4 Cyl 2.4L; Deluxe; 5-Speed Manual Transmission FS5W71B; Long Bed Truck; Four-Wheel Drive; Federal Check another vehicle.What is says about the part Mike listed.22301-80W00 Edited November 28, 2024 by Thomas Perkins Quote Link to comment
datzenmike Posted November 28, 2024 Report Share Posted November 28, 2024 22301-80W20 is for the 4x4. 22301-80W00 is for '85- 2wd except HD. No mention of California emissions so good for Federal /California. 1 Quote Link to comment
Thomas Perkins Posted November 28, 2024 Report Share Posted November 28, 2024 (edited) My bad,I looked for them and can't find any.Post it on Facebook and you will get one. Edited November 28, 2024 by Thomas Perkins Quote Link to comment
85"720 Posted November 29, 2024 Author Report Share Posted November 29, 2024 I've found those oem part numbers but can't find anything that cross references them. Quote Link to comment
datzenmike Posted November 29, 2024 Report Share Posted November 29, 2024 Any Z24 distributor vacuum advance canister will work. Emissions has no way to check this. Vacuum advance add ignition advance is response to throttle input. More throttle = less ported vacuum = less advance. Less throttle = more ported vacuum = more advance. None at idle and basically none the closer to WOT you get. Quote Link to comment
85"720 Posted November 29, 2024 Author Report Share Posted November 29, 2024 1 hour ago, datzenmike said: Any Z24 distributor vacuum advance canister will work. Emissions has no way to check this. Vacuum advance add ignition advance is response to throttle input. More throttle = less ported vacuum = less advance. Less throttle = more ported vacuum = more advance. None at idle and basically none the closer to WOT you get. I understand that. The thing is that the z24 distributor or any 720s in general are pretty rare in my area. It looks like I might have to buy a new distributor just to get a vacuum advance pot. Quote Link to comment
NC85ST Posted November 30, 2024 Report Share Posted November 30, 2024 Post a wanted ad on here. Quote Link to comment
Sephakrid Posted December 2, 2024 Report Share Posted December 2, 2024 I picked up a couple vacuum advances for a 1986 Nissan Stanza a while ago, but haven't tested them yet. They at least look the same! Quote Link to comment
datzenmike Posted December 2, 2024 Report Share Posted December 2, 2024 There are 12 vacuum canisters for the '84 720 depending on multiple things like man or AT transmissions ... and 8 possible ones for the Stanza. The parts numbers do not match, they might fit and if they do it will work, but all are set a different advance under part throttle. Quote Link to comment
Sephakrid Posted December 30, 2024 Report Share Posted December 30, 2024 (edited) So, I tested the Stanza vacuum advances. They are not identical (of course). However, I heard that Hitachi vacuum advances are adjustable so I went ahead and drilled out the sealant to see what was inside. It seems like the outer screw adjusts the rate of advance, while the inner screw adjusts the total advance. Unfortunately, the first "step" seems to be non-adjustable. For instance, you'll always have 4° at 13.3 kPa regardless of how you adjust the screws. Either way, I plan to mess around and see how close I can get using the available adjustments. Edited December 30, 2024 by Sephakrid grammar 1 Quote Link to comment
datzenmike Posted December 30, 2024 Report Share Posted December 30, 2024 Bravo, I would have not bothered. But this is interesting to know. 1 Quote Link to comment
