720 Leafs
On my SWB 2wd 720....it has sagged a few inches in the rear.  I load the heck out of it and tow w/it.  I want to restore it to stock height.
What will 4x4 springs do to it?
What about D21 springs....will they fit?  I have a 4x4 D21.
  • Replies 4
4x4 springs will be lower and stiffer.
Have your springs re-arched at a shop. Have the shop bent so that it has 6.34" of camber. This is the distance down from a line stretched between the two end eyelets.
What about adding a set of those helper bags to rear?
It would also help when loaded up and towing with it...
No way to know without putting them on. 520/521/620 and 720 are all the same 1,200mm length. D21 might be the same for length but if 4x4 they will be flatter, less arch. Don't you want to be higher?.
