Diego Zuniga Posted November 11, 2024 Report Share Posted November 11, 2024 I am pulling my hair out on trying to figure out how do I keep the little bearing in it's little copper pocket. Behind the indicator lever. In my picture it's goes between the two orange painted spots. Bearing is I believe what makes the contact between high and low beam. Quote Link to comment
datzenmike Posted November 12, 2024 Report Share Posted November 12, 2024 My 710 hi low also has a small BB and spring but it's not for contact but to allow a rocking movement of the contacts. Once out, it was not easy to get it back together. Quote Link to comment
mklotz70 Posted November 12, 2024 Report Share Posted November 12, 2024 I've never actually torn one apart. I looked at the parts and service manuals and didn't find anything helpful. I briefly address it in part of a video I did....a long time ago!!! So many UMMs and AHHs! 😞 The camera didn't focus on the correct spot either. It's as close as I've gotten to the high beam switch. I know I have an extra switch around here somewhere. If you still can't get it to stay in there, msg me and I'll see if I can dig out mine and take a look at it for some better ideas. I've used some dental floss to hold brushes in when reassembling starters and generators....and small DC motors. Not sure if that would work with a ball. The idea is to use the floss to hold them back and then once assembled, you can pull it back out. I'm not sure just what the issue is for you. Is it falling out after being assembled? Is it that you can't hold it in place to assemble it? A few more details might help a bit. If it's during assembly, maybe a few more close up pics with the pieces apart. 1 Quote Link to comment
Diego Zuniga Posted November 12, 2024 Author Report Share Posted November 12, 2024 11 hours ago, mklotz70 said: I've never actually torn one apart. I looked at the parts and service manuals and didn't find anything helpful. I briefly address it in part of a video I did....a long time ago!!! So many UMMs and AHHs! 😞 The camera didn't focus on the correct spot either. It's as close as I've gotten to the high beam switch. I know I have an extra switch around here somewhere. If you still can't get it to stay in there, msg me and I'll see if I can dig out mine and take a look at it for some better ideas. I've used some dental floss to hold brushes in when reassembling starters and generators....and small DC motors. Not sure if that would work with a ball. The idea is to use the floss to hold them back and then once assembled, you can pull it back out. I'm not sure just what the issue is for you. Is it falling out after being assembled? Is it that you can't hold it in place to assemble it? A few more details might help a bit. If it's during assembly, maybe a few more close up pics with the pieces apart. 11 hours ago, mklotz70 said: I've never actually torn one apart. I looked at the parts and service manuals and didn't find anything helpful. I briefly address it in part of a video I did....a long time ago!!! So many UMMs and AHHs! 😞 The camera didn't focus on the correct spot either. It's as close as I've gotten to the high beam switch. I know I have an extra switch around here somewhere. If you still can't get it to stay in there, msg me and I'll see if I can dig out mine and take a look at it for some better ideas. I've used some dental floss to hold brushes in when reassembling starters and generators....and small DC motors. Not sure if that would work with a ball. The idea is to use the floss to hold them back and then once assembled, you can pull it back out. I'm not sure just what the issue is for you. Is it falling out after being assembled? Is it that you can't hold it in place to assemble it? A few more details might help a bit. If it's during assembly, maybe a few more close up pics with the pieces apart. I watched your videos and at 15:45 you talk about high beam switch. So there is a little ball bearing that sits in there on copper piece. They seem to just fall out. I cannot seem to find how or what hold the little bearing in there. Quote Link to comment
mklotz70 Posted November 13, 2024 Report Share Posted November 13, 2024 (edited) I would think that the ball is the detent that holds the switch lever in on position or the other.....and not actually part of the switch contacts. Have you taken the assembly apart before? No clue if this matches anything on yours, but it should give you an idea about what I mean with the ball being a "detent" rather than part of the contacts. I was slightly confused when you put the time....15:45....in your response. I meant to put the link in to start right at that time. When doing this link, I realized I didn't select the "start at" box. Sorry. lol On this one I did. 🙂 Edited November 13, 2024 by mklotz70 2 Quote Link to comment
