Y44 v8
Adam Garrison
  • Replies 17
6 hours ago, Adam Garrison said:
Ryan C the fan can be removed it just 4 bolts. It fit nicely in my 78 Z.
Thanks Adam, anychance you can measure the length or near enough rear of engine to crank pully wheel outside etc?  Looks pretty compact like most pushrod v8s.
I looked at a SBC and no way it would fit a 620 by 5-6". Ford is likely similar. Water pumps and fan would have been in the radiator as there was too much room in a GM car or truck for a V8 to need to make them compact. All v8 swaps I have seen the firewalls were cut out and engine set back to clear radiator.
It's a cool motor looks to be a combination of Ford dodge and Chevy. I really wanted to leave it in the car was having a hard time finding someone to build me an HEI distributor for it. The SBC parts are readily available so it just makes sense. I've put the older Chevy motors in all kinds of things this is my first LS swap gonna be fun the Edelbrock kit makes it easy from what I'm seeing.
LS with remote water pump electric fan setup and custom radiator everything else is gonna be custom sooo hmmm 🤔
6 hours ago, datzenmike said:
LS will make more power, and, EFI.
Were some aluminum block? Keep the weight down.
Yep our local gen 3 5.7 ls1s were alloy we had lots of them in the Holden's but think they weren't common in the states.
