A10 chassis flooring -- See inside
Xiao_Hu
So I measured a stock 510 wagons floor tub and I am reasonably certain that it will work to patch my much later A10 chassis car. To that end I will be ordering a set of front floor pans ASAP.
The width measurement that I got on the stock 510 was 22 in from sill to trans tunnel (at sill height) I got similar measurements from my 510.
After I take care of the floors my next biggest project on the car (I'm currently working on getting it running) is gonna need to be cleaning the interior and finding rocker panel and wheel arch/rear lower quarter patch panels or even just fabricating them myself. This car was previously improperly repaired with rivets.
Again I'm not looking for a perfect car so I am going to continue doing research. I will post photos and results when I have the new floor panel bonded in. My strategy is going to be cutting the edges flush where the floor needs to patch, taking sheet metal strips and panel bonding them to the edges of the tub, then panel bonding the panels to the floor pan. The result will be that the interior is flat, but the bottom will have a set of strips indicating it has been repaired. Seam sealer will be applied to all seams to make everything water tight.
I'm also looking at building a custom grill because the 1978 has an ugly ass grill
  • 5 months later...
  • Replies 1
Posted (edited)
Back to this finally. I decided to patch the rear floors at least with sheet metal to just get it fixed and driving again.
Spent the day cutting the driver side rear floor. Wednesday I gotta work on my friends Honda, but if I have time I'm gonna clean the edges up, flap disc away all the rust up top and bottom, then use cardboard to make the shapes and install it. Then I'll do the passenger side rear floor, then work on the front driver side floor. I also cut a chunk of their rockers and sent it to my Greek metal fabrication guy and he's gonna make me a rocker set.
Once I do all that, gonna fix the interior up some more and get the key situation sorted, fix the carburetor up and boom, should be drivable enough for basic around town shit. Probably going to redo the entire front suspension and I also gotta patch the trunk, wheel arches, battery tray and rear quarters in a lot of places but the fucker runs and stops.
Edited by Xiao_Hu
