DwayneOxford Posted October 25, 2024 Report Share Posted October 25, 2024 (edited) Losing ignition when in crank position. Wanting to get contact cleaner into it. Anybody know if it'd get in around the plastic actuator? Wondering about drilling a hole between the B & S where white mark is, as they are far apart or between I & R as they're even farther apart. Also like to know how far back to drill. Can get one at Rock for $15 if I kill it. Edited October 25, 2024 by DwayneOxford Forgot pics. Quote Link to comment
Thomas Perkins Posted October 25, 2024 Report Share Posted October 25, 2024 Are you sure that is the problem? My second fuse in the fuse box comes loose and I have to bend the tabs a little bit to get a good connection,then it starts.I almost did what your fixing to do.My ac fuse use to do that,the fuse would come loose,and I would just push it in. 1 Quote Link to comment
DwayneOxford Posted October 26, 2024 Author Report Share Posted October 26, 2024 Not positive, but turned to ign. I oft have to wiggle switch to make contact. I'll check the fuse connection. Quote Link to comment
Thomas Perkins Posted October 27, 2024 Report Share Posted October 27, 2024 Must be switch. Quote Link to comment
DwayneOxford Posted October 27, 2024 Author Report Share Posted October 27, 2024 I think I got contact cleaner by actuator and cycled several times, followed with CorrosionX. Gonna leave fuses be to try switch. Also CorrosionXed connectors and 4 way while apart. 1 Quote Link to comment
Thomas Perkins Posted October 27, 2024 Report Share Posted October 27, 2024 I hope that works for you. 1 Quote Link to comment
DwayneOxford Posted October 27, 2024 Author Report Share Posted October 27, 2024 Thanx, we'll see. In process I figgerd out why tilt wheel was not staying up. Posted it on my old thread about it. Quote Link to comment
