PanDulce037 Posted October 16, 2024 Report Share Posted October 16, 2024 Just bought a 1982 720 diesel and it doesn’t have a key but can start and with a screwdriver and the issue I’ve had is that when I turn to key the off position it doesn’t shut off and It I had been using the choke it has which I’m also not sure is original or some aftermarket stuff but that doesn’t shut it off either not sure where to start on making so I can shut it off if anyone got an ideas I’d appreciate it Quote Link to comment
wayno Posted October 25, 2024 Report Share Posted October 25, 2024 OK, these are the photos I have, this one is how the choke cable is connected to the arm on my injection pump so I can shut down the engine if the key don't work. This one is a photo of the arm connected to the injection pump(top), and the injection pump controller below the injection pump. If you do not have that arm or electrical component below the injection pump, it will never shut down with the key, you will then need to buy everything needed or use a choke cable to shut the engine down. Quote Link to comment
