84' nissan 720 2x2
FXRS-DRTBAG
Have rough idle/engine shake.
Work done: new plugs/wires, cap rotor, fuel filter, rerouted all vacuum lines.
Issues: mixture screw unresponsive to adjustments, running very rich
Fuel is at half on sight glass, timing is around -3° BTDC, both coils have spark (one dramatically stronger than the other). Choke fully disengaged at operating temp.  Carb rebuild looks like an absolute nightmare so I was hoping maybe I'm looking over something simple. Please help!
  • Replies 2
Did this roughness just start recently? Like when the plugs and wires were changed?? Important that you answer this question.
Timing must be +3 degrees or Before Top Dead Center. Not -3
One coil seems to have better spark? Switch the wiring on the + and - terminals to the other coil so that the intake coil is now the exhaust side coil....
Did the stronger spark change to the other coil???
