521 /510 external volt reg
  • Replies 4
the silver one from Autozone are the weak ones DO NOT BUY. or ground really good otherwiswe they will pop.
I have a digital volt meter in CigLighter spot. when the VR goes bad it will over volt and most people will not know. when overvolt you can put lights and heater on and the alternator does not load down in voltage. thats how you know they bad. Most people wont know till battery bulges if lucky the Alt Light might come ON
the older mechanical one is a Bosche boxed repackeage Japan made unit. which are better(with resisitor
Edited by banzai510(hainz)
