1984 720 ECU
Sephakrid
I just thought I'd post some pictures of the 1984 ECU my friend picked up from the junkyard recently. It's pretty simple on the inside, with what appears to be through-hole components throughout. Also, these early ECUs seem to have the inspection light toward the rear. Basically, you have to look from behind the driver's seat to see the light.
  • Replies 1
That's for a May '83 to May '84 California emissions King Cab and will have the ECC carburetor. This is as close as a carburetor can get to EFI.
The inspection light may only be an indicator that the unit is on. Later Z24i which DID have TBI had a diagnostic mode and stored fault codes that were saved could be accessed to help diagnose running problems.
