danielsca Posted December 21, 2008 Report Share Posted December 21, 2008 Hey I am new to this forum. I have a 69 1600, however the Marine Corps decided I would be put to better use in Japan. While here I bought a Mazda 13B with a turbo. I want to put this in my car however I need some measurement from the engine bay. Any thing would help mostly I need to know the distance from the front crossmember to the firewall and between the chassis from left to right. If I am correct this motor should fit with room to spare but I don't have my car here to confirm or test fit. Thank you for any help that can be give. Quote Link to comment
datzenmike Posted December 21, 2008 Report Share Posted December 21, 2008 Well, you bought it so you are committed anyway, so bring it home with you. As you say it'll probably fit but if not you can always sell a JDM 13B. Quote Link to comment
Icehouse Posted December 21, 2008 Report Share Posted December 21, 2008 IMO roadsters are the hardest datto's to do swaps on, the steering column bar is a bitch!! I don't have measurements but I know with a welder and grinder anything is possible :D Quote Link to comment
datzenmike Posted December 21, 2008 Report Share Posted December 21, 2008 ...I prefer a wire feed wrench to tighten things down.:D Quote Link to comment
Icehouse Posted December 21, 2008 Report Share Posted December 21, 2008 ...I prefer a wire feed wrench to tighten things down.:D And the blue tip wrench to take off the wire feed nuts :D Quote Link to comment
