Drummerboy4as Posted December 21, 2008 Report Share Posted December 21, 2008 Not sure if this has be posted here before, but it was sent to me so I'll pass it on. Very cool electric 1200 running 11.50 sec 1/4 miles (clickety click) Quote Link to comment
ggzilla Posted December 21, 2008 Report Share Posted December 21, 2008 It is posted like once or twice every week :-). You can use the Ratsun "search" menu to search for white zombie to see the previous discussions By the way, nice pic. It was taken at Portland Internation Raceway. I raced John in my own '72 white Datsun 1200 2-dr. Guess who won? Quote Link to comment
freaky510 Posted December 21, 2008 Report Share Posted December 21, 2008 that is a nice shot. i heard it going to be faster next year rollcage 4 link rearend and all Quote Link to comment
Figbuck Posted December 22, 2008 Report Share Posted December 22, 2008 There was a segment on Oregon Field guide that show on OPB. They showed him putting a new battery pack in and running in the 10s now. I have been tripping on electric cars for a couple years now. There is tons of cool stuff like this out there. Posts about EVs come up randomly in other threads, maybe I will start a new thread. Quote Link to comment
cheg Posted December 22, 2008 Report Share Posted December 22, 2008 yeah figbuck i've had that as my signature for a while Quote Link to comment
thisismatt Posted December 22, 2008 Report Share Posted December 22, 2008 Specs here: http://www.plasmaboyracing.com/whitezombie.php I wonder if a 2 speed trans would help his top end? Quote Link to comment
freaky510 Posted December 23, 2008 Report Share Posted December 23, 2008 Specs here: http://www.plasmaboyracing.com/whitezombie.php I wonder if a 2 speed trans would help his top end? lol it has a 2 speed motor and its direct drive it runs off a dial for forward and reverse :eek: cut and paste baby[ Drivetrain: Direct drive (no transmission, clutch, or flywheel). Electric reverse. Custom aluminum driveline by 'Inland Empire Drivelines', 'Dutchman Motorsports' heavy duty 'Street Strip' rear setup with Dutchman 31 spline racing axles, Aluminum 'Strange' Ford nine inch differential with Detroit Locker, lead acid version uses 'Richmond Gear' ring and pinion @ 4:11 ratio, lithium ion version uses 'Strange' ring and pinion @ 3:70 ratio, custom made traction bars. Thanks to Dutchman Motorsports and Inland Empire Drivelines for their support. Quote Link to comment
Skib Posted December 23, 2008 Report Share Posted December 23, 2008 repost but badass non the less, his brother roger is a fellow Z club member Quote Link to comment
thisismatt Posted December 23, 2008 Report Share Posted December 23, 2008 lol it has a 2 speed motor and its direct drive it runs off a dial for forward and reverse :eek: cut and paste baby[ Drivetrain: Direct drive (no transmission, clutch, or flywheel). Electric reverse. Custom aluminum driveline by 'Inland Empire Drivelines', 'Dutchman Motorsports' heavy duty 'Street Strip' rear setup with Dutchman 31 spline racing axles, Aluminum 'Strange' Ford nine inch differential with Detroit Locker, lead acid version uses 'Richmond Gear' ring and pinion @ 4:11 ratio, lithium ion version uses 'Strange' ring and pinion @ 3:70 ratio, custom made traction bars. Thanks to Dutchman Motorsports and Inland Empire Drivelines for their support. I know...I posted the link. It's not a "2 speed motor" though, it's 2 motors joined at the hip and switched from series to parallel wiring to change the input voltage at each motor so that they'll spin faster. Quote Link to comment
freaky510 Posted December 24, 2008 Report Share Posted December 24, 2008 I know...I posted the link. It's not a "2 speed motor" though, it's 2 motors joined at the hip and switched from series to parallel wiring to change the input voltage at each motor so that they'll spin faster. uuuhhh isnt that a second speed if your going 5000and flipa switch and now your doing 10000 i would think that would be uuuuhhhmm a second:rolleyes: Quote Link to comment
thisismatt Posted December 24, 2008 Report Share Posted December 24, 2008 uuuhhh isnt that a second speed if your going 5000and flipa switch and now your doing 10000 i would think that would be uuuuhhhmm a second:rolleyes:Not really in the typical sense, at least not to me. Seems it's like saying a honda engine is a 2 speed because it makes max torque at 5000rpm (~series motors) but max horsepower at 7000rpm (~parallel motors). Maybe a lot of thought has gone into it, I don't know...I don't have a background in DC motor theory. Quote Link to comment
slodat Posted December 24, 2008 Report Share Posted December 24, 2008 A series wound DC motor (field and armature windings are in series) is good for torque but has poor speed control. Classic example is your car's starter motor. A shunt wound DC motor (field and armature windings are in parallel) has great speed control and a rather linear torque-speed curve with great no-load speed control, but poor starting torque. A compound DC motor uses both with a varying shunt percentage to balance the starting requirements with the speed control requirements. This is rather simplified, but will hopefully help. Quote Link to comment
